@maty
As far as magnetic shielding, aluminum is not the way to go, even thick chassis walls. Yes, CNC chassis look nice and work great for heat dissipation, but the magnetic permeability is not good at all.
Relative magnetic permeability
Vacuum: 1 perfect
Air: 1.0
Aluminum: 1.0
Carbon steel: 100
Iron: 5,000
Mu-metal: 20,000 to 50,000.
https://en.wikipedia.org/wiki/Permeability_(electromagnetism)#Values_for_some_common_materials
So applying mu-metal around big transformers of linear power supplies is going to shield it a lot more than thick aluminum chassis walls. Mu-metal shielding is already used by some high-end audio manufacturers.
And mu-metal sheets are cheap, about
$20 per sheet on eBay. Using scissors, just cut strips of the sheet with width the same height of the transformer, and install a couple of circles around it. Some sheets have self adhesive, so it is possible to stick it to itself, so that it is easy to install and remove and compare.
In other words, a 0.004" (0,10 mm) thick mu-metal sheet has the same magnetic permeability as 78" (2 meters) of aluminum, worst case (20,000 relative permeability).
