Ah... now I get it
I have a class AB power amplifier with 450W in 4 ohm for my two WO24P in parallel per side. On top of this, I have 4 subwoofers (12" and 15" )driven by 4 x 1400W - I like headroom and peace of mind
Reason I use subwoofers, is because it smoothes out the response in the entire room and is able to pressurize the room in a totally different way, than any normal speaker with "small" woofers can. My room is also quite large and has "soft" wooden floors and walls, which absorb more bass, which means that I need more, to experience the same sensation of bass.
I drive my Satori with no HP, and just let them "have it" from 400Hz and down - and find them not struggling, even at quite loud volumes. They each have a 35 liter closed volume.
Having no HP filter, eases the subwoofers integration somewhat, since there is less phase-issues.
Letting them play "all" bass frequencies + my subwoofers - also gives me 6 sources of bass - which smooth it all out even more.
The 4 Satori alone can play OK bass - but they still don't play this deep physical bass, that my subwoofers can do with ease. I also like my cabinets closed, which of-course limit the deepest bass from the Satori. Mine drop slowly below around 65Hz - naturally because of the small closed volume they play in.
May I suggest another solution?
What if you simply did not use the limiter at all - but set the input stage of the Fusion amps to something like -10-15dB - so that the WIIM Ultra can be turned to MAX, without reaching the limit of the Satori excursion?
This way, you still protect your speakers from being overdriven, and even if someone "trips" and turn the WIIM all the way up, the lowering of the input gain on the Fusion amps, would prevent you from playing too loud.
My system has an 10 channel DSP, and I can never really overdrive it, since I can set the gain in my DSP, to never reach the max level of my speakers or amplifiers. This way, the limit is the MAX setting on the pre-amplifier.
