welwynnick
- Joined
- Dec 26, 2023
- Messages
- 1,400
- Likes
- 1,774
The improved test results that you linked were the reason I said "if you don't take Amir's test too literally." Perhaps I should have been more explicit. I think Amir's test was unfairly negative, and I took the improved measurements into account.If your only criteria for not putting HTP1 in first place is Amir’s review, there is the below updated review. If you really dig deep on the HTP1 latest capability (check out AVS forum thread), I think regardless of price (it is still the lowest priced out of all of them I believe, especially if you pick up a used one as I did!), it has the crown
'Monolith HTP-1 AV Processor Measurements (June 2023 Firmware + User Testing)'
https://www.audiosciencereview.com/...ements-june-2023-firmware-user-testing.47365/
However, it's not just down to the FFT and SINAD. Amir takes many other measurements, such as dynamic range, multitone, linearity and jitter, and the APR-16 excelled at those as well. That's why I said "When you look at ALL the test results".
