welwynnick
- Joined
- Dec 26, 2023
- Messages
- 1,561
- Likes
- 1,975
I was going to mention that, I don't know why I didn't. It's a well-established method. In actual fact I think there is a little bit of magic going on. SINAD includes distortion, and the DAC doubling or quadrupling trick improves noise, so the SINAD wouldn't be that great if the distortion isn't great, too. The T16 (like the APR-16) uses ESS Hyperstream IV DACs, which have remarkably lower distortion than the older Hyperstream II (like the ES9038), and the T16 does have low distortion. Despite the Hyperstream II and IV DACs having much the same THD+N and DNR on the ESS datasheets. One trick that miniDSP might be using is to phase the DACs in order to get some even order harmonic distortion cancellation, which is a neat trick. Not sure if they do that. It's mentioned in the datasheets under "Analogue Features".There is no magic here, just sound engineering. The chips in the Tide are multichannel and if I recall correctly each audio channel uses 4 DACs. If you do the math on what results to expect on how signal, noise and distortion add up, then that’s how this SINAD happens.
True. It was me that pointed out that the Hyperion DACs had ASRCs and the miniDSP DACs did not.One area where the Tide was weak was jitter and that is not helped by their DAC architecture. The chips in the APR are better at handling jitter from what I’ve read. And I believe it shows up in the tests Amir did.
https://www.audiosciencereview.com/...nel-atmos-dts-x-high-sinad.68883/post-2506085
