Hyperion APR-16 AV Processor Review
Rate this AVP:
    Votes: 18 8.4%
    Votes: 70 32.6%
    Votes: 82 38.1%
    Votes: 45 20.9%
This is dissolving into another SINAD chaser vs non-SINAD chaser thread (nothing wrong with either philosophy). I suggest everyone cool their jets and just focus on the important stuff, like the value proposition of the APR16...
The difference between stereo DACs is audible, so AVRs even more so.
Count me as a doubter. With music playing 87 sinad is inaudible to all but the most trained ears.
But the anticipated DPR-16 might be more relevant.
Sure, key word is "might". To most HT users, it is just another new kid on the block, nothing compelling, even the all "digital" feature is not a tech breakthrough as it simply shifts the function to the other piece (power amp) that is a requirement. Back to @PGAMiami 's original point about the much bigger Tide thread than this one, the reasons would still stand if the DPR-16 is eventually added to this same thread, just my guess only.
Me too, and I'd like to repeat for the nth time, we should question that 87 dB test result, if we look at the consistent results of the 3500,3600,3700,4700 and 6700, all seemed to be >95 dB, and 87 dB is an obvious outlier for the Denon 3000/4000/6000 series since around 2018.
I am not suggesting Amir should always measure a second sample, but case in point, he did measure the 4700 twice, and measured two samples of the 6700, two samples of the SR7015, and AV7705. In the cases of Denon, he got 97 dB vs 87 dB between the two tests on the Denon AVR-X4700H, and 99.5 dB vs 87 dB between the two samples of the AVR-X6700H. If we were to accept the first tests of the 4700 and 6700 we would be saying the same thing about those, as we are now, about the 3800.
I would have thought ASR members typically think logically and would therefore question the results if collaborating information warrants, such as in this case, the 3800, so I am somewhat disappointed to see that I seem to be the only question doubting the specific 3800 Amir measured, to be clear not doubting Amir, but the DUT itself.
I hope someone like @EWL5, if and when he upgraded to something else, would send his 3800 to Amir and join the long queue, so we may get a second chance to see if the relatively low 87 dB SINAD is repeated.
I'll leave speculations and analysis of the audibility of highly spec'd components to @Mort, @peng and others.
My view is that when a component is highly spec'd, such as the Hyperion, and those specs are confirmed by bench testing, especially bench testing on this site, it suggests high quality design and build. Conversely, lower spec'd components suggest mediocre design and build.
I would definitely have found a way to purchase the Hyperion, given its superb audio specs and interesting, useful combination of features, had it not been for the Tide, even with its beta software and that it has not been bench tested, the price difference was to much for me. An educated gamble based on my past experience with the manufacturer. But if cost was not a factor, I would have purchased the Hyperion. Confirmed excellent specs indicates excellence in design and build. I leave it to others to debate audibility.
I am not disputing your statement but my perspective is that multichannel power amps, stand-alone or integrated, will be of decreasing utility as channel counts increase and wireless/active speakers become more common.
Let me throw a big fly in this ointment… I had one of the first APR16s. It’s the one Amir tested. So why did I end up returning it? It’s correctly pointed out above that Amir essentially tested the DACs and the APR16 did exceptionally well versus other AVPs. But what I learned is that there is much more to an AVP than the DAC, they are very complicated and they suffer from many quirks. Some quirks are very audible. Some are functional. Some take a while to find. The APR16 has quirks just like all other AVPs. It’s very difficult if not impossible for Amir to test Dirac ART in an objective way. It’s going to perform differently in different rooms and with different speakers etc. I felt like I was one of maybe a handful of posters that had an APR16. And for me this wasn’t enough because I feel it is very important to have an AVP that many other people use because this is the only way to really understand if it’s working correctly. I ended up with a Trinnov because I find it reassuring that studios trust their DSP algorithms. To me ART sounds great and as I’ve written it’s a bargain especially in lower priced receivers. But the lack of clarity from Dirac on how ART does what they say it does with absorbers and emitters bugged me. I feel more comfortable with Waveforming. But I also agree that Trinnov is very expensive and in many many cases a Dirac based system could be just as good if not better.
So just installed one of these guys in my home cinema yesterday. So far I have not done anything but do a by ear PEQ change to the mains. This processor sounds very good so far on both music and in multichannel. Once I spend some more time with it I will do a review of what I am hearing. I am not really a numbers guy any more. After spending years mixing live music for multiple venues, I am pretty sure I know what I like. So far clean and detailed is what I am hearing. My room is fully treated so Dirac won't do much in the EQ sense. If it sounds this good out of the box, then I have highi hopes after calibration. They have done an outstanding job with the WebUI.
There's a big firmware update due end of this week approx. It's currently going through testing at AudioControl.
"My room is fully treated so Dirac won't do much in the EQ sense"
Can you expend on this?
It’s very unlikely room treatment is doing much below 200hz. Dirac ART will do wonders there.
The Tide16 takes the SINAD crown by a mile
Yes, those are good numbers. But an 8 dB difference doesn't define a good processor—the software and its synergy with the hardware do.
So let's see who wins that race.
The software side is tricky now that they've transitioned to ARM-based hardware, but it's very flexible once they get everything dialed in. It will allow the platform to evolve over time—provided the companies actually have the incentive to keep supporting it. Which is great news for us consumers
Agreed, the software is critical. DACs may set a cap for performance. Bugs can surely make that much worse. These are extremely complicated units and in my view they have been rushed to market, but at you can see lots of effort to get them right.
Truth is the DACs in both APR and Tide are probably more than good enough. How they sound will vary mostly on how well the software works and on whether they were properly set up.
It's not always quite as simple as that, PGA. The T16 uses ESS ES9017 DACs. ESS claim -110dB THD+N, against Amir's measurement of -116dB (and miniDSP's -118dB). It's unusual for an AVR or AVP to measure better than the manufacturer's DAC spec; it's almost always the other way round.
There is no magic here, just sound engineering. The chips in the Tide are multichannel and if I recall correctly each audio channel uses 4 DACs. If you do the math on what results to expect on how signal, noise and distortion add up, then that’s how this SINAD happens.
One area where the Tide was weak was jitter and that is not helped by their DAC architecture. The chips in the APR are better at handling jitter from what I’ve read. And I believe it shows up in the tests Amir did.
This is all well and good but the Tide16's jitter was below the audible threshold (per Amir). The only reason to really point to these graphs is bragging rights only. I think owners of either the APR16 or Tide16 deservedly can have pride of ownership w/o the need to become apologists.
