Hyperion APR-16 AV Processor Review
Rate this AVP:
    Votes: 18 8.4%
    Votes: 70 32.7%
    Votes: 82 38.3%
    Votes: 44 20.6%
In my opinion, and also logically speaking, more expensive may not always result in “better”. Trinnov waveforming may or may not be better than Dirac ART. Ultimately it would depend on individual use cases, as there are other factors, beside the software/technology.
Also need to keep in mind that one of the reasons Trinnov waveforming naturally costs more because of the well known effects of the ecomy of scale, Dirac must have sold millions of licenses of different versions.
Well I'm shocked. You were the one leading the charge against buying a Storm or Trinnov. What do you think a Trinnov does better?
Nick
I continue to be a fan of Dirac ART, especially given the value offered with the Denon 3800/4800. The relative ease of setup vs Trinnov is a big plus. But I feel like Dirac is a black box and I have more control with Trinnov. But it’s much more complicated to set up. For me that’s part of the fun. But I can see how many would be intimidated by Trinnov. The price of the Altitude 16 was just too much. That said the CI is much more affordable and I can use most any DAC with it. It also has a much improved user interface.
Any users out here who are enjoying the APR-16?
Have all or most of the bugs been resolved via firmware updates?
Is D-ART included when you buy this processor?
Dirac is not included. 3 or 4 people on AVS received theirs in the last week, I know one was shipped back immediately as faulty, will see what the other say soon.
I am the one that had to send it back. But they next day'd me a new one. And it worked from the get go. It sounds great. But we still have bugs. I have been so busy though it's hard to take the time to call them and go over them. I haven't run Dirac yet and no license in the box. Paid option. Actually though it is better at this early stage than my Emotiva XMC2 and RMC1 and RMC1L were at a late stage. Yes I tried all three of those at different times. I guess I am very forgiving. But the switching is better. Locks on quick. And is stable. But I am having some little audio glitches randomly that I can't figure out. I will be calling them about those. But right now other than the known Screen dimming to off at startup, Dirac has to be full range for all speakers before running it I guess. I think there might be one more little thing I can't remember. But it does sound good. And it switches great for me.ymmv though.
Can you provide some sort of Atmos test file that does a tone sweep in the top speaker positions? (Not sure how most of us can confirm this issue without a targetted test file)
MUSIC
You can verify whether the decoding functionality is malfunctioning simply by testing track playback using this Apple Music album.
I don't have Apple anything. It's hard to test anything with top speakers only. I mean you could shut off all other amp channels. I can't do that because of my amps unfortunately. I can't unhook speakers without blowing up each amp module that doesn't have resistance across the outputs. Goes to DC at the low end.
Actually I actually read the post you linked. When I run Dirac I will be able to tell. You would see the drop in the low frequency in the graph of the heights. I haven't paid for it yet though. I will probably sometime this week.
I am testing the raw audio decoded directly by Dolby, not the signal processed by the DSP. It is the unprocessed LPCM signal captured straight from the AXIS-16.
Normally, it should look like this screenshot. I tested different channels, and they should all align at the exact same sound pressure level (SPL) for proper decoding. This reference curve was generated using macOS's built-in Dolby Atmos decoding.
Any further update?
You said it's stable but I'm concerned about the audio glitches.
AVPro support told me there'd be a big firmware update for the unit post CEDIA, which was last week. Can't see it available for my demo unit yet and it needs it.
I am confident that I am not alone in looking at the Hyperion APR-16 as my next AV purchase. Moreover, I suspect that I use the same room and essentially most of the same equipment to both watch movies and listen to two-channel (plus subwoofers) music. Lastly, like many others, I seek a preamp/HT processor that provides state-of-the-art room equalization.
I draw from three sources to listen to music: vinyl records, CD/SACDs, and streaming. Over the years, in both software and hardware, I have made substantial investments in the equipment I use to play them – and the outputs of my phono preamp and my DAC are analog. Currently, I own a Theta Casablanca Va, which an excellent preamplifier/HY processor. However, it is limited in what it can do; for example, while the Va does incorporate Dirac Live, it is too “processing weak” to handle BassControl and ART. For that reason, I am shopping for its replacement.
A problem for me with all the better HT processors, e.g., StormAudio and Trinnov, is that they immediately convert all analog inputs into digital. Fortunately for me, my Theta Casablanca Va has a pure analog bypass circuit, so no digital conversion of my original analog signal ever occurs between the input from analog sources and the output to my left and right main speakers. Unfortunately, no signal is sent to my powered subwoofers either.
So, one may ask, what’s the big deal? For me, that automatic A-D-A conversion is a showstopper. There is simply no way that the DAC stage in an HT processor is as good as my DAC is, nor is the signal from my phono preamp as refined after undergoing an A-D-A conversion. There are frequent times that I am willing to forgo the benefits of Dirac to be able to hear a more unprocessed version of the music.
This brings me to my question about the Hyperion APR-16. I have read its owner’s manual from cover to cover and spoken to one of AVpro/AudioControl’s “tech support” personnel, asking him whether their Hyperion has a setting to enable a pure analog bypass. He did not know and never got back to me with an answer. The manual does not address this matter either.
Thus, I present this question to the participants in the Audio Science Review. Does the Hyperion APR-16 incorporate an analog bypass capability and, if so, how does it work?
All responses are appreciated. Thank you.
