Hi.
I will tell a little about a project that started in Sweden and in the beginning was a passive loudspeaker. The goals where to create a good loudspeaker with good directivity with driveunits that were good but not really expensive. This passive loudspeaker were not developed by me.
I bought the closed boxes from the inventor of the passive loudspeaker , and decided to develop an active dsp model with the same driveunits using a dbx pa2 dsp and tpa 3251 amplifiers from Aiyima. The name became HYBRID. Its a closed box loudspeaker that can be used by itself with Linkwitz transformer in a small room with lots of roomgain. Or as a main loudspeakers designed to play with dual subwoofers crossed at 80 Hz.
The drive units are seas er18rnx and a scanspeak ringradiator. The waveguide is a Monacor WG300 with a custom made adaptor made of mdf. Damping material is sheep wool.
Crossover frequency is 2,3 kHz linkwitz Riley 24 dB/oct.
