Humming from xlr cable, pin 1 connected to shell
dasherzx
I bought an xlr cable that was wired this way and I seem to be getting ground loop hum noise when connected to a subwoofer. Should I unsolder the wiring to shell and just leave it connected to pin 1? Would this be a potential fix? I have another cable that doesn’t produce this hum, and it’s not wired like this.
See here:
Summary:
Dave Rat, the person who does the PA system for Coachella, compares different GND configurations in XLR cables with practical examples and hum tests.
informative vid. that explains why my setups behave differently. i guess this is on a case by case basis and for my situation there's no use having the shell connected
Looking at the quality of that solderng I would also suspect a short from the shield to one of the signal cables - which would turn it into unbalanced. Check that out if you have a multimeter.
Then never buy a cable from that supplier again
Yeah, shoddy workmanship. But it costs $1.50 for a 1.5m so you get what you paid for I guess.
