Let's see..
- Grid regulations limit DC injection to a maximum of 0.5%.
- Even as little as a few hundred millivolts of DC can cause a toroidal transformer to hum.
Since 0.5% of 120V AC is 600mV DC, it’s possible for the grid to stay within legal limits while still causing issues.
I'd say only after verifying that the amplifier is functioning properly and that no internal faults are causing the issue should you consider a DC blocker. Using one might mask a deeper problem rather than truly fixing it.
Let's review:
I recommended a DC blocker if eliminating potential DC sources in one's own home did not fix the problem.
You responded: "By following the steps you outlined,
you've effectively ruled out DC as an issue, rather than confirming its presence on the AC mains."
I responded by noting that no, this is not necessarily true, because sources of DC don't only come from within one's own home.
And you then responded,
"it’s possible for the grid to stay within legal limits while still causing issues."
That is precisely my point: DC can absolutely be present in the AC supply at levels that can cause issues, especially with toroidals as they are more susceptible to those issues than EI's are. It would be nice if you'd acknowledge that you're actually agreeing with what I said rather than proving it wrong, although I won't get my hopes up given our past exchanges here.
My understanding is also that in dense environments with multiple homes connected to the same transformer, a neighbor's devices can cause voltage drops, added noise, and other issues in one's own home AC supply - though I freely admit that while I have read that these effects can include DC injection, I am not certain if that is the case.
In any event, if a toroidal is particularly susceptible to DC-induced hum, we can speculate as to whether it's poorly made, or it's well-made but the AC supply has a good amount of DC in it, or perhaps the toroidal's build quality is mediocre
and the AC is a bit dirty with DC. The average home user will have no way of making those distinctions, particularly since the standard for "good" vs "bad" toroidal core construction employed in this thread so far is quite fuzzy.
And speaking of fuzzy, if you could specifically list some common, testable faults that would result in mechanical toroidal hum in an otherwise normally functioning amplifier, and which would not be simply "bad quality toroidal," that would be helpful.
