The new media room is waiting for carpeting. In the meantime I'm getting stuff out of storage and ready to install. The room is W12." x L22' x H7.2ft. It will contain a single couch and be used overwhelmingly by only 1 or 2 people. Today's question is rear and side speaker selection. My general path is to get 2ch and 7.1 up and running (placement, acoustic treatments, etc). This will be a dual use system for both video (7.1, maybe 7.2 etc) and 2 ch audio wherein the fronts will do double duty for both. Installing Atmos height speakers for 7.x.2 or 7.x.4 will follow later after 2ch and 7.1 is dialed in. The fronts are already decided, Magnepan MGIIIa's - ancient but recently factory rebuilt to better-than-new. They were the predecessor to the more familiar 3.7 family, so placement issues are about the same and I've got that covered. Less clear are what to use for the side and rear speakers. Here's the selection:
As some wise man once said, "Do what you can, with what you've got, where you are." So, to be clear, these are the speaker choices. Please let's not suggest other choices, starting over, etc etc. Also, I will move things around, so no reason for "put it where it sounds best." What I'm looking for are pros and cons of respective placement scenarios. Looking forward to ideas and comments. Thanks and cheers,
- KEF LS50's (bookshelf),
- MG Quart Ones (older bookshelf but quite capable)
- Maggie SMGc's (essentially same as the newer MMG's)
