Hi everybody!
I would like to ask you for an advice on my new ht setup. Right now I am using some old Q Acoustics 1050i floorstanders together with NAD D3045 stereo amplifier for both music and movies and I decided to make it little better (now there is no bass at all and overall the sound is crap). Since I figured out I watch movies for like 80% of time I would like to move to HT. So far no rears, just good 3.1 or 2.1, 3.0... not sure. To be honest, there is no much space for a beefy subwoofer in my living room so I am wondering if some bigger floorstanders with decent low frequencies would be enough.
So far I have looked at these:
Polk Reserve R600
KEF Q750
KEF R5
ELACs Debut and UNI-FI
Viewing/listening distance is 3m and the open living room with kitchen is around 40sqm. There could be a potential problem with not so much distance of speakers from a wall which can be max 10-15cm. So bottom/front bass reflex?. Not sure if it really helps.
About center channel, I like Monolith THX if I can even tell the difference from the phantom center.
Budget: +- EUR1500, second hand is totally fine
Really appreciate any help!
Polk Reserve R600
KEF Q750
KEF R5
