HSU CCB-8 Speaker Review
Rate this speaker:
    Votes: 169 88.5%
    Votes: 18 9.4%
    Votes: 2 1.0%
    Votes: 2 1.0%
This is a review and detailed measurements of the HSU CCB-8 "constant directivity horn" speaker aimed at home theater market. It was kindly drop shipped by a member and costs US $389 each.
I kind of like the subwoofer styled, chunky enclosure. Back side shows dual ports which came partially plugged:
CCB-8 home theater speaker coaxial constant directivity horn port reard back review.jpg
But I read the instructions and it suggested leaving them open so I tested it that way. But do show the difference in one of the measurements.
The manual also recommends listening off-axis at 15 degrees. The intent seems to be wider sweet spot (which you can get from any speaker). For ease of measurements, I used 0 degrees but again, show what would happen if you sat at off-axis.
As usual, measurements were made using Klippel Near-field Scanner with the magnetic grill removed (as seen in the picture above).
HSU CCB-8 Speaker Measurements
As usual, we start with the so called spinorama family of anechoic frequency response measurements:
CCB-8 home theater speaker coaxial constant directivity horn anechoic frequency response audio...png
Wow, I did not expect this seeing how this is a design collaboration with the famous designer, Don Keele. We have some kind of massive cancellation centered around 1.7 kHz. Same region presents directivity error which goes against the ethos of the speaker marketing material. With the dirctivity index climbing, we don't have constant dispersion either. While we are missing a lot of lower treble energy, we have excess amount which is mostly mitigated if you listen at -20 degrees:
Sensitivity is a good 5 or so dB better than average speaker I test which is the main good news here.
Near-field response of the woofer shows classic effect of ports:
CCB-8 home theater speaker coaxial constant directivity horn woofer frequency response audio m...png
And this is the response of the ports and woofer:
CCB-8 home theater speaker coaxial constant directivity horn driver port frequency response au...png
We see the sources of our frequency response errors given that large resonance from the port/cabinet between 1 and 2 kHz where woofer response is down.
Going with our 0 on-axis response, early window and hence predicted in-room responses don't look that good:
CCB-8 home theater speaker coaxial constant directivity horn early window frequency response a...png
CCB-8 home theater speaker coaxial constant directivity horn predicted in-room frequency respo...png
The high sensitivity pays dividends in loudness where the sweep was quite clean at 86 dBSPL:
CCB-8 home theater speaker coaxial constant directivity horn THD distortion audio measurement.png
CCB-8 home theater speaker coaxial constant directivity horn relative distortion audio measure...png
Being designed for home theater, I also tested it at 101 dBSPL:
CCB-8 home theater speaker coaxial constant directivity horn 101 dBSPL THD distortion audio me...png
I could clearly hear distortion during the sweep.
Directivity is anything but "constant:"
CCB-8 home theater speaker coaxial constant directivity horn horizontal beam width measurement.png
CCB-8 home theater speaker coaxial constant directivity horn horizontal directivity measurement.png
CCB-8 home theater speaker coaxial constant directivity horn vertical directivity measurement.png
If you go off axis as recommended, you then get more uneven directivity at higher frequencies due to its roughness and narrow width.
Impedance is typical for bookshelf speakers at a bit below 4 ohm:
CCB-8 home theater speaker coaxial constant directivity horn impedance phase audio measurement.png
It naturally exposes (low frequency) resonances.
As does csd/waterfall measurement:
CCB-8 home theater speaker coaxial constant directivity horn CSD waterfall measurement.png
Step response shows uneven output from the tweeter:
CCB-8 home theater speaker coaxial constant directivity horn step response audio measurement.png
Let's just say at this point I was not very motivated to listen to this speaker.
I don't know if it is the price point or lack of attention to optimizing multiple design parameters but we have quite a messy speaker here. The sacred on-axis response is quite poor with its large suck out which is harder to fix with EQ than peaks. I guess with high sensitivity you could pull the rest of the spectrum down but then you lose the one advantage the CCB-8 brings to table. It is claims of constant directivity are not visible in any measurements.
Needless to say I can't recommend the HSU CCB8 speaker. Company's reputation demands that they do better!
From the website: The CCB-8, a constant directivity horn made in collaboration with Don Keele, is one of the industry’s best performing speakers when it comes to smooth, musical, off-axis response.
  • Point source ensures no lobing effects because you’re always the same distance from the woofer and tweeter
  • True constant directivity (circular) horn allows for a smooth, musical, off axis response regardless of whether you’re vertically, horizontally, or even diagonally off axis
  • Horn loaded coax gives increased efficiency in the higher frequencies
  • Maintains linear responses even when 15 degrees off axis
Agree, it's a bit of a mess really... unfortunate, but thanks for the in depth testing on this Amir.
Other external measurements (not with an NFS) show a similar story too;
Pics;
JSmith
So I'd say false marketing and poor execution then, definitely not recommended then!
It's truly disheartening to see, day after day, products being analyzed that are essentially scams. Thank you to Amir and all contributors for your invaluable, objective analyses and measurements.
I think this speaker model has been around for nearly 20 years now with no changes/updates that I know of.
That big dip is right around the crossover, said to be 1.5kHz. Looks like the crossover needs a lot of work, almost like the two drivers are out of phase in that region.
Being optimistic, HSU could improve this speaker for future runs without a complete redesign / retooling? [I'm not an engineer!]
HSU hasn't figured out traditional speakers, they should not attempt coaxials.
They should review their entire product range, not just the coaxial speakers.
