Not sure where to post this so please move if inappropriate here...
So I will soon have 2 AE Dipole 18 subs in h-frames and 2 CSS SDX12 subs in sealed cabinets. I would like to put the dipole subs on the front wall near my Accoustat 6600's, and the sealed subs either on the side or back walls. I will use dsp, an Okto 8 channel dac, and several 2 channel amps. I have a few questions regarding how best to wire the subs:
1. wire a pair per side of the dipole and sealed subs in parallel, then connect the pair to each left and right amp channels in stereo? ( would be a 2 ohm load per channel, which my amps are fine with)?
2. wire each pair of subs to their own amp channel, meaning 4 amp channels instead of 2, in stereo?
3. wire as in 1 but feed the two amp channels the same signal (mono)?
4. wire as in 2 but feed the 4 amp channels the same signal (mono)?
5. Something else?
I should add that the AE dipoles have dual voice coils, 8 ohms each, the CSS sub drivers have dual voice coils, 2 ohms each. If I wire the 2 dipole voice coils in parallel, I get a 4 ohm load, if I wire the CSS voice coils in series, I get a 4 ohm load as well. I could then put the dipole and css drivers in parallel for 2 ohm load, or in series for an 8 ohm load, if I understand things correctly.
Any help greatly appreciated.
5. Something else?
