UltraNearFieldJock
How to shift the operating range of an amplifier while keeping the speaker volume constant?
Imagine the following situation:
A Class‑D Hypex Ncore NC400 power amplifier receives its input signal from a DAC through a passive volume control (potentiometer). The amplifier output drives a Visaton AL180 (8 Ω) loudspeaker directly. According to the specifications, the amplifier’s output impedance is only 3 mΩ. My ears are only a few centimeters away from the speaker, so I need extremely low listening levels—basically like using headphones.
The problem is that the passive volume control is very sensitive in this low range, so adjusting the level accurately is difficult.
The optimal operating range (“sweet spot”) of the amplifier is approximately 5–20 W (see the figure below).
Is it possible to increase the input signal level while keeping the actual acoustic volume of the loudspeaker very low and constant?
My first idea was to place a low-value resistor (e.g., 2 Ω or less, 10 W) in parallel with the loudspeaker so that the amplifier’s output current increases, but with more current, (less resistance) the amplifier’s parameters become worse (the graph in the picture shifts upward)..
Another idea is adding a series resistor (e.g., 30 Ω or more, 10 W) to increase the amplifier’s output voltage, but this would severely worsen the damping factor.
Perhaps the best solution is simply to buy a more suitable, lower‑power amplifier, but maybe you know a hack to answer the question.
