It's trivial. Your mini-i Pro 4 outputs about 15.1 dBu at 0 dBFS. With this output, your Genelecs will be forced to generate about 115 dB SPL at 1 m at the lowest sensitivity setting (+6).would you explain more detailed reason?
Thanks for your reply.It's trivial. Your mini-i Pro 4 outputs about 15.1 dBu at 0 dBFS. With this output, your Genelecs will be forced to generate about 115 dB SPL at 1 m at the lowest sensitivity setting (+6).
Now, there are two quirks about that:
1) The speaker is not designed to generate such SPLs (it has peak SPL rating of 110 dB and short term max SPL rating of 104 dB), so its limiter will be actively engaging, distorting the FR;
2) such volumes are very much uncomfortable.
So I would actually look for a way to even further attenuate the signal (using passive attenuators, for instance).
4.4Vrms = 15.08dBuHow to get this information - "mini-i Pro 4 outputs about 15.1 dBu at 0 dBFS"?
Thanks.4.4Vrms = 15.08dBu
On line Calculator by Reference Audio Analyzer
reference-audio-analyzer.pro
You can simply reduce the volume.Thanks.
In this case, shall I get some "passive attenuators", what is the actual specs I should get?
or, can I reduce the volume to make it better?
I would still opt for the attenuators. By using them, you optimize the DR of your setup and also, by setting the attenuation so that even at the maximum volume on your mini-i Pro your speakers still will not exceed safe sound pressure levels, you protect your hearing from accidents caused by user error or by software glitches.that's great. As long as it doesn't affect the sound quality, I'm fine to listen at lower volume.
Would give more detailed brand/specs of attenuators that I should choose?I would still opt for the attenuators. By using them, you optimize the DR of your setup and also, by setting the attenuation so that even at the maximum volume on your mini-i Pro your speakers still will not exceed safe sound pressure levels, you protect your hearing from accidents caused by user error or by software glitches.
Courtesy of @MC_RME, there is this thread at the RME forum with some suggestions and discussion: https://forum.rme-audio.de/viewtopic.php?id=25399Would give more detailed brand/specs of attenuators that I should choose?
I'm afraid I don't really get the question. You set the knob on each of your speakers to "+6" position, and that's it, no fiddling needed. Being not very familiar with the Genelecs, I don't know if the knob is notched or is it continuously adjustable. Well, with the "+6" setting it should not be a problem since it should be at the hard stop of the knob.is there a quick way to set both speakers to same sensitivity? after I changed one, it is hard to set the other one to same level sensitivity.
Genelec 8030C's sensitivity adjustment knob is continuously, thus only the max and min values are hard stops. max=-6, min=+6.Courtesy of @MC_RME, there is this thread at the RME forum with some suggestions and discussion: https://forum.rme-audio.de/viewtopic.php?id=25399
Yesthe lower the sensitivity I set, the more volume range I can adjust
the higher the sensitivity I set, the smaller the volume range I can adjust
Not generally.and the smaller the volume change produced by each volume step value
and the larger the volume change produced by each volume step value
Right.Anyway, it has no effect on the sound quality itself, right?
Only possible if your volume control uses a logarithmic curve where steps at the lower range are larger and steps at the upper range are smaller.I found that after setting the sensitivity to +6, I need to adjust many step values to hear the change when adjusting the volume. Although I can adjust the volume more accurately, it is more inconvenient to use. If the sensitivity is set to -6, it only takes a few step values to adjust the volume to a satisfactory volume, which seems to be more convenient.
To be honest, after read the 8030C and mini-i 4 pro manuals many times, I still cannot understand which paramaters are connected.Yes
Not generally.
Right.
Sure you can.Can I reduce the mini-i 4 pro volume to a value, which can match 8030C's max acceptable power?
Little correction, with +6 dB setting Genelec 8030C will produce 109 dB SPL. “+6 dB” in Genelec convention means that a +6 dBu signal will give 100 dB SPL @ 1m. Therefore 15 dBu signal will be at 15-6 + 100 = 109 dB SPL.It's trivial. Your mini-i Pro 4 outputs about 15.1 dBu at 0 dBFS. With this output, your Genelecs will be forced to generate about 115 dB SPL at 1 m at the lowest sensitivity setting (+6).
There’s no standard on monitors sensitivity in music production but generally studio monitors are built with a 4 dBu signal in mind, and an alignment level with the source at -20 dBFS to that voltage (1,2 Vrms).Below are snapshots of the Genelec 8030C Matrixaudio mini-i Pro 4.
mini-i Pro 4 output level: 4.4 Vrms @ 0db.
which level shall I set for the 8030? -6, -3, 0, +3, +4, or +6?
After going around a lot, I found that many professionals that work with studio monitors advise to keep the gain knob at its maximum gain to avoid tonality alterations when lowing sensitivity.Below are snapshots of the Genelec 8030C Matrixaudio mini-i Pro 4.
