Hi,
Well, not exactly kitchen items
More like laptops, audio interfaces and whatever gives me the best audio quality. Not advanced multimeters, oscilloscopes, etc.
I bought an Arturia MiniFuse 2 OTG expecting it to work perfectly on the go with consumer grade lavs and mics, maybe prosumer in the near future like the Sanken COS 11D?
I thought I just needed the right adapter from XLR or 6.35 mm jack to 3.5 mm. But there's no bias power. Why Arturia? It's just 2 to 5 V?
I bought two adapters that convert phantom power to 3.5 mm bias power. They work, but surprise, the noise is extremely high.
Then, based on recommendations online, I found out that the right converter shouldn't just provide bias power. It should also convert the signal from unbalanced to balanced. But that costs around 40 pounds (Rode VXLR Pro).
So I thought, fine, I'll ditch phantom power and use bias powered lavs, like the Boya BY M1 with LR44 batteries (great for the price!)
But what about the other lavs? I thought about making my own mini amp, then AI suggested the generic ME1 lavalier amplifier, which seemed to have pretty much everything I was about to build, with very low self noise.
I also found other models, like the generic MIC 60, with EQ, XLR combo, 3.5 mm in/out and unbalanced to balanced conversion. Seems like a good deal, although it has a bit of noise.
Then I bought a good deal of pencil mics that need phantom power. The MIC 60 doesn't provide much juice, and the MiniFuse may have a problem with its phantom power, so...
I bought an Xvive P1 portable rechargeable phantom power supply with a switch between 12 and 48 V.
More testing. With 48 V from the Xvive, I got roughly the same noise level as with the MiniFuse 2. But at 12 V, it works flawlessly, with only about 2 dB of gain loss.
Comparing the noise levels of some old dongles, I was surprised by how bad the mic input on the original iPhone USB C to 3.5 mm TRRS adapter is, and how good the Sabrent USB C 3.5 mm TRS in/TRS out is.
But all of this started because I needed a clean stereo signal, not mono.
So I started looking for USB dongles with stereo input. The Rode was the typical expensive answer, but then I bought the Cubilux CB5 for 27 pounds.
The Cubilux gave me headaches, but after some brainstorming I managed to get SIX separate channels out of it!
The problem is how the channels are exposed through different interfaces. WASAPI in Windows, instead of seeing one input interface, sees three.
With VoiceMeeter Banana (super cool app), I created a virtual interface mixing all three stereo input channels.
One weird thing with the Cubilux. You need to plug the mics in first and then power the unit on. Otherwise, the additional interfaces don't show up.
So that's been my newbie budget audio adventure so far.
But after running into so many budget bottlenecks, I really need a proper way to test all this stuff, rather than relying only on my rusty ears. At this point, I'm probably somewhere around 20 Hz to 14 kHz, with some tinnitus distortion specially in the mornings
My first priority is to get ADC values, SNR, EIN or any other useful input signal measurements.
How do you guys test this stuff?
