How to measure and neutralize overall EQ boost/cut?
Multicore
If I want to decide if I like an config in EQ APO then I would A/B it with another or with a null config.
I understand that even small difference between A and B in "level" or "loudness" is likely to bias the preference.
How can I measure and neutralize that difference?
I don't even know what to measure.
How I would do it: To put your A and B settings on even footing, use pink noise and a LUFS meter like this in EQAPO: https://youlean.co/youlean-loudness-meter/ - this uses weighting based on loudness contours so you get a weighting that matches hearing better.
Put the meter at the end of the chain. Get the loudness of A. Switch to B and add a preamp filter and adjust it to get it to the same loudness as A.
While the variation in total loudness of program material will tend to vary even after doing this (the spectrum won't be the same as pink noise, so the outcome could be different) I think this is probably a good start?
I'd use ReplayGain component within foobar2000 after saving the two different digital tracks, one saved using the EQ APO settings. Then read the two ReplayGain values within foobar after running ReplayGain, then use Audacity's amplify function to decrease the track with the higher ReplayGain value by the difference in the two values. Verify the two tracks have the same ReplayGain within foobar after rerunning ReplayGain on them (mouse right button menu just takes a second).
Then you can use ABX Comparator component within foobar to playback the two tracks in blind fashion to decide which one you really like.
Chris
Probably! But I don't see a perfectly good ending. If frequency responses are quite different when compared.
