Hi everyone,
I recently purchased a new miniDSP Flex 2x4 Balanced (TRS) from an authorized European distributor. I am trying to determine whether this specific unit features the original Texas Instruments PCM1795 DAC implementation or the newer Dual ESS ES9017 DAC revision, without opening the enclosure and risking warranty/return eligibility.
The reseller mentioned their stock arrived fresh from the factory recently, but they cannot verify internal component batches because the retail packaging and external labeling remain identical across production runs.
Here are the specific details from the Device Console and serial tag:
Thanks in advance for any insights!
- Model: miniDSP Flex 2x4 Balanced (TRS)
- Serial Number: 900-59xxx
- MCU Firmware: 1.85
- DSP Firmware: 2.0
- Bluetooth Firmware: MD5124-SPK-LDAC-I2S-V013
- Is there any known software method, board revision marker, or Device Console readout that differentiates the PCM1795 units from the ES9017 units?
- Does anyone with a confirmed ES9017 Flex TRS unit have matching or higher MCU/DSP firmware versions reported in Device Console?
- Side question regarding thermal behavior: My unit becomes noticeably warm to the touch even while sitting completely idle with no audio stream playing. Is this typical thermal dissipation for the Flex Balanced chassis?
