ChrisUpNorth
- Joined
- Mar 7, 2025
- Messages
- 23
- Likes
- 19
Hi and Happy new Year! As per the heading I'm trying to get a clean digital signal from my DMP-A8 into the Mac Mini M1. Not sure whether this is the correct forum by the way.
As digital outputs, the DMP-8 has:
1. USB audio out (type A connector)
2. Optical out
3. Coaxial out
4. IIS out
Of course there are analogue outs which I could use instead but I want to avoid multiple digital to analogue conversions and keep the signal purely digital until it reaches the Hapi Mk3.
I've tried connecting the USB audio out to the Mac directly but the DMP-A8 says there is nothing attached so the Mac isn't advertising itself as a DAC or DDC (wasn't even expecting it to).
Am I correct in thinking I need a USB-based DDC that when plugged into the Mac will accept Optical/Coaxial/IIS as an input from an external device such as the DMP-A8? Will the DMP-A8 accept a DDC attached to it, rather than a DAC? (I have used it with an external DAC before).
By the way I need the Mac in the middle because it has Dirac Live Room Correction Suite installed and also processes sound my AppleTV/Dobly atmos decoder using Dante. DLRC uses the Ravenna Virtual SoundCard to output to the Hapi. Everything sounds great but just want to add the DMP-A8 into the chain to complete the setup.
The end solution must support sample rates up to 192kHz! Dante is no good as it maxes out at 96kHZ.
Any advice appreciated, thanks!
2. Optical out
3. Coaxial out
4. IIS out
