This is because Apple mandates that Atmos mixes have 18 dB of dynamic headroom, unlike stereo mixes which can have as little as 3 dB but more usually about 6-8 dB (for popular music). Hence the Atmos tends to be a very superior mix, dynamically.You will have to use the apple tv 4k app. Have to warn you that the volume will almost always be about 6db less requiring you to turn up your volume.
If you turn on Apple Sound Check, it should normalise the average playback volume. But I don't do it because I am not sure how it does this.Then if you listen to a non atmos track BOOM it will then be too loud.
I assume you have front height speakers? My AV unit won't allow Auro 3D without them. Your recommendation is interesting, I hope to try it one day when I finally get FH speakers.I also have some atmos tracks that have infrequent loud pops from one or two of my surrounds to height channels. I have since switched to auro 3d’s upmixer, auromatic, for regular tracks. It presents a nice front wall of sound with surrounds offering a concert hall like spaciousness.
I have tried both methods, but it still doesn’t work. I wonder if anyone has managed to get it working. Because Denon’s official description says it is supported.I heard the 3900x can do it.
Did you try via Heos?
因为天龙官方描述说支持。AirPlay 2不能做到这一点——它携带立体声ALAC,没有Atmos流的路径,所以Denon将只能通过AirPlay看到2个通道。Atmos必须通过HDMI进入:Apple TV 4K(或PC)进入AVR,Atmos已启用,AVR处于匹配声音模式。Golfx关于水平差异的说法也是正确的——Atmos混合设置得更低,所以设置您的参考音量并保持它。
play Apple Music Dolby Atmos Spatial Audio through AirPlay 2AirPlay 2 can't do it - it carries stereo ALAC and has no path for an Atmos stream, so the Denon will only ever see 2 channels over AirPlay. Atmos has to come in over HDMI: an Apple TV 4K (or a PC) into the AVR, Atmos enabled, and the AVR in the matching sound mode. Golfx is right about the level difference too - Atmos mixes sit lower, so set your reference volume and leave it.
Which Apple device are you streaming from that has Airplay 2 (iPhone, Macbook, etc.)?I have tried both methods, but it still doesn’t work. I wonder if anyone has managed to get it working. Because Denon’s official description says it is supported.
Hi, I want to know how to play Apple Music Dolby Atmos Spatial Audio through AirPlay 2 on my Denon AVR-X3900H.
What settings do I need to enable on the AVR and iPhone?
Will AirPlay 2 send the full Dolby Atmos bitstream to the Denon receiver?
I've read about this feature previously and your post made me curious. I just skimmed the x3900h owners manual and I do not see anything in there stating that the 3900 can direct stream Apple Music Atmos multichannel content. Can you show where "Dennon's official description says it is supported", I can't find that in the owners manual. Also in the manual all Airplay references state that ios 11.4 or newer is required. Reading Dolby materials it looks like the ability to stream Apple Music Atmos multichannel content is restricted to streaming directly to an Apple product (like paired Homepods) and it requires ios 18 or better. Guessing that if the x3900h did indeed have this capability they would also be requiring ios 18 or newer and would call that out somewhere in the manual.
A report from May 2026 speculates Atmos playback via Airplay 2 for the Denon AVR-X3900H may depend on a later firmware update.
That may explain why the manual has no mention - so far.
Perhaps this feature will go live after iOS 27 is released on September 14, 2026.
www.audiosciencereview.com
14promax and airWhich Apple device are you streaming from that has Airplay 2 (iPhone, Macbook, etc.)?
See if this website helps:
Apple AirPlay 2
Learn how AirPlay 2 works with Denon products, and how to use it to stream audio from your Apple devices to your home audio system.www.denon.com
On Denon’s official flagship store in China, you can clearly see marketing descriptions regarding wireless Dolby Atmos transmission. However, I have tried both HEOS and AirPlay 2, yet I cannot get genuine Dolby Atmos bit‑stream output. I’m wondering if anyone has managed to make it work.
天龙(DENON)AVR-X3900H家庭影院 9.4声道215W功放进口专属声...【图片 价格 品牌 评论】-京东
京东JD.COM是国内专业的网上购物商城,为您提供天龙(DENON)AVR-X3900H家庭影院 9.4声道215W功放进口专属声...价格、图片、品牌、评论、等相关信息.item.m.jd.com
noWhat does your owners manual state as far as functionality, not the (possibly deceptive) marketing materials?
HEOS (inside your Denon AVR) communicates directly with the providers servers not from your phone. The app on your phone just selects the songs. Tidal offers atmos via HEOS.What does your owners manual state as far as functionality, not the (possibly deceptive) marketing materials?
