- Joined
- Dec 25, 2023
- Messages
- 651
- Likes
- 719
Here's how you can find what music has bass in stereo so you know if you need stereo subwoofers or not. I use Linux so I also use EasyEffects which makes this task shockingly easy.
1. Add a Stereo Tools widget and invert the phase in one channel, left or right
2. Add another Stereo Tools and combine both channels into one mono ("Mono Sum L+R")
3. Add an Equalizer and set it to Low-Pass, 2x slope, and frequency 120Hz or around that
Done! Now you'll only hear stereo bass content. If your music doesn't use stereo bass you'll hear nothing. These steps are so generic that you could apply the same idea to the Mac/Windows equivalent of EasyEffects.
If you get rid of the equalizer, you'll instead hear whatever isn't center panned, bass or not. If you use only the invert phase step, you can test speaker crosstalk.
I tested some of my favorite music and found that there are generally no stereo bass guitars, synths often have stereo bass, and classical recordings have stereo bass if the instruments are bassy (cello and upright bass). For bass guitars, it seems like what little you can hear of them if they're not obviously panned is the residuals of crosstalk in the analog recording equipment.
