Because I have a Kindle 4K that I am using for Amazon HD music, it is connected my AVR and I need HDMI video output to the TV.
Thinking about I could try connecting it directly to the TV and using and optical connection. But this might complicate things with the WAF as it will require 2 remotes or I will need to purchase a universal remote.
Which Jensen Iso Max transformer do I need, they sell a million different ones and their also quite expensive.
Since balanced connections will eliminate ground loops I would get the "unbalanced" Iso Max so you can use it in the future on some other balanced ground loop, that model is CI-2RR. Of course you could replace your AVR with one that had balanced out but that would be even more expensive but maybe worth it if you sell your current one?
I agree that the HDMI connection is going to cause ground loops even if you use optical for audio.
