my_ears_are_up_here
Just received a brand new Topping E50 after a bunch of headaches, only to find something is rattling around inside. By the sounds of it, it seems like a free screw. Nothing else seems to be rattling around, so I'm hoping it just fell in during assembly and went unnoticed.
After all the time and trouble I had to go through to get this thing (long story), I'd like to take it apart and — if that's the only problem — pull it out and be on my way.
I took the three torx screws off the back, but nothing has loosened up. I don't want to start to make permanent changes to it, but I'm wondering if there are additional screws under the rubber feet? Or is there a security screw under the (laughable) QC sticker on the side?
I'm happy to turn it upside down to let the screw rest on the top and plug it in to ensure that it works, and if so, don't mind violating warranty to get inside and remove this confounded screw, but I don't know if there are exposed leads on the back that it might touch, so if anyone has a picture of the inside, that would be helpful as well.
Any help would be appreciated. Thanks!
