I used to run arc genesis on anthem av receiver with 3.1 setup by using microphone from anthem
To test with pink noise
How could a pure analog cintosh c8 tube pre
Do bass management like anthem
Can this tube pre setup a 2.1 with mk v12+?
But mcintosh dont come with microphone to test pink noise,and it only has sub out port of c8 tube pre
How many hz cutoff from front speaker is properly?
The anthem tested 80hz as front crossover by using arc genesis?
Lastly,what is the difference between anthem str pre,str int and avm processor?
Does str has difference with avm70
