Roland68
Used integrated amplifiers are even cheaper than AVRs, you can get really good ones for €20-100.Thanks for replying. Used Avr s are easy to find also i can connect my phone directly to steam music or airplay. Most of the integrated amplifiers are expensive.
The reason i want to use external dac is because this external dac has the latest akm chip which i want to use to see if therenis any sound difference overall. I am not looking for any tiny details but overall if it sounds better and also external dac supports MQA.
Inexpensive AVRs usually have cheap and poorly or too simply integrated DAC chips.
The others are usually old or used and significantly more expensive.
