Pariah Zero
My office setup has a floor plan somewhat like the following:
The screen is the entire width of the desktop, and it's in an alcove of sorts, with 1m long walls on each side.
The issue I have (or at least, the one I'm interested in mitigating) is that while the center channel sounds more or less clean, the left and right channels seem to have an "echo," and it seems to be at about human vocal frequencies. I imagine it's simply the sound reflecting off the adjacent walls, and is at least partly due to the fact there's no toe-in (or even room to do it right now).
If I want to reduce that echo, I imagine some sort of stand where I can toe in the speakers would help. Maybe there's a benefit of using acoustical panels on the left and right walls? I'm not sure what to prioritize (if anything).
For what it's worth: the back wall is flat, and about 10 feet from the front wall; the right wall has a door, but when it's closed it continues to the back wall. (I could update the layout picture, but I'm not sure it'd help)
So... where would I start? I have REW and a calibrated UMIK-1, so I can certainly make measurements. I don't know how to use them to identify the problems, but I can make them.
Thanks
Thanks
