Does it work with Roon?Dirac's Standalone DLP (both Stereo for $349 and Multichannel $499) is now available.
https://live.dirac.com/home-audio-2/
If you click Buy, it says "Plug-in version", which is confusing.
I contacted Dirac, they will fix this soon.
Yes, it acts like a virtual sound device (via WASAPI) in Windows (I was beta testing it now for two months or so with Roon).Does it
See post #43Any update regarding the standalone version availability?
Got it, I edited my message.See post #43
Hi, should be possible. Let me find out. I will get back to you...I’ve got two setups at home, both Win 10, Roon Core & Endpoint.
Is it possible to install Dirac Stdalone on both PC’s with one license?
1) I got a demo license for 14 days to test it, and the license is not valid, so I cannot test the correction. I'll have to contact Dirac....
2) I followed the set up guide and as you say I can see Dirac in Roon via WASAPI. But how can I stream Roon to my my streamer (Chromecast Audio) if I select Wasapi?
Thanks
Thanks for the tips. As soon as I get my demo license working I'lltry.Hi,
this might be the solution for you: https://www.audiosciencereview.com/forum/index.php?threads/windows-to-chromecast.11110/
I went through it very quickly, to me it sounds like it could be possible to use it in the following way:
1. use Dirac WASAPI as Roon's output device
2. install VB-cable virtual audio device
3. in Dirac DLP set the VB-cable as audio device
4. configure VB-cable so that its output is connected to Chromecast Desktop Audio Streamer (app from the link above)
Best,
Well, in Dirac you have to set some output device, so unless the Chromecast Desktop Audio Streamer can act as a device, you need the cable, I guess.Thanks for the tips. As soon as I get my demo license working I'lltry.
Is VB Cable actually needed? Chromecast Desktop Audio Streamer shows Dirac here, but I haven't tried.
tested couple of days ago and returned to vst which is more convenient to meI personally not tested it yet as quite happy with vst version
