hutt132
- Joined
- Jul 25, 2019
- Messages
- 72
- Likes
- 110
Update: Test results in this post https://www.audiosciencereview.com/...d-i-a-b-test-headphone-amps.8186/#post-203680
Update 2: Some more setup comparisons https://www.audiosciencereview.com/...b-test-headphone-amps.8186/page-2#post-247035
I’m wanting to A/B test two headphone amps from a single DAC, with as little delay as possible between switching.
The two ways I thought about doing this are:
1) Use a switcher between the DAC and the amps and have a 2 male to 1 female 3.5mm splitter plugged into the output of both amps. This way my headphone is plugged into both amps, but only one amp is getting a signal passed to it via the switcher.
2) Use RCA splitters from the DAC to feed both amps and have a 3.5mm switcher on the output of both amps. This way the amps are both amplifying the signal to their output, but the outputs to the headphone are switched between them.
Would there not be a difference between these two setups?
Could a 3.5mm splitter cable damage the outputs of both amps, even if only one is being passed an audio signal?
I was looking at either the Nobsound Little Bear MC1022 or Nobsound Little Bear MC22 for these two setups, but am taking suggestions for a similar priced alternative.
