ZolaIII
- Joined
- Jul 28, 2019
- Messages
- 5,730
- Likes
- 3,430
In short environmental noise should be kept -18 dB bellow the SPL program, headphones are capable to go loud but on the long run its not very healthy. Ambient awareness is a good thing when you need it.
long version I love open earbuds on the go specially during the summer, use IEMs when I really need more isolation (T2 work around the property). Have particular design taste towards semi open back (as a port reinforcement and passive filters) however ended up using closed back easy to deploy ones (almost guaranteed seal) because I am lazy. they isolate pore especially for what they are and even so enough for gaming at average front listening SPL (about 76 dB listening program), they also aint hot. You can put and some effort making damn thing little more quiet (optimized profiles) and move it away from you (5.5 to 6 dB less with every doubling of distance) and not too close to walls and corners. Most of the time I can and use speakers with good ELC integration (worked out listening room 2.2 setup).
