Do you have any tips on how to make sense of such ratings for laymen like me? When is S/N ratio very good and what about uV?
I think the Purifi stuff comes in around 30-32 uV residual noise, but what on earth does that mean?
Signal to noise ratio is a somewhat deceptive number. For a given amount of noise (hiss, whatever you want to call it), the signal is the level above said noise, and measured with respect to full rated output into a given load.
It's a voltage relationship, specified in dB (decibels). So, manufacturers pick the highest voltage they can and the lowest residual in V (uV normally) to come up with a number. They will also "weight" the noise and specify a bandwidth. The bigger the number the better, as it sells more amplifiers.
Trouble is, the more powerful your amplifier is, the more voltage it develops, and, for a given residual noise level, the S/N number will be bigger by default. So, free ride!
Let's take an example:
A 100 watt per channel amplifier at 8 ohms will develop 28.28V RMS over that 8R load. (take the sqr root of 100x8)
Let's say it has 50uV of residual noise (unweighted).
Take 28.28V, divide it by 50uV and you get 565,685.42.
Log that, you get 5.7526.
Multiply by 20 (as we are talking voltage, not power for dB) and you get 115dB.
So, all things being equal, your 100 wpc amplifier with 50uV residual has a 115dB S/N ratio.
Let's do the same with the Purifi you mentioned (off the published specs)
It has 11.5uV of residual, A WTD. (a very low residual noise- amazing in fact, due to its very low gain in part)
It is rated at 425 watts at 4 ohms.
Let's see how it works out:
425 watts at 4 ohms is 41.23V (take the sqr root of 425x4)
The residual is specified at 11.5uV
Divide 41.23V by 11.5uV and you get 3,585,309.24
Log that, you get 6.5545
Multiply by 20 (as we are talking voltage, not power for dB) and you get 131dB.
What is Purifi's dynamic range spec? (in real terms, it's the same as S/N in this case)
So, we know the math works out.
So, the Purifi is incredibly quiet, but it also has very low gain of only 12.8dB (x4.3) without a buffer stage. For some rare individuals, that may be enough. For most, it is not remotely enough. A normal amp is around 26-29dB (x28). So, you put a buffer up front to increase the gain, but with that gain comes some noise. Noise that the amplifier dutifully amplifies. You can see the issue?
