Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Welcome to ASR. There are many reviews of audio hardware and expert members to help answer your questions.
Click here to have your audio equipment measured for free!
I'm curious what others think about speaker selection as a room/system-matching problem. Assuming a speaker has adequate anechoic measurements, how much weight do you give to the actual room when choosing between speakers? How much does it change your buying decision? Do you pick the best-measuring speaker first and adapt room/system around it or do you define your room's constraints first and then choose the best speaker that fits those constraints?
In our theater room design, we had the luxury of starting with a large open space, clean sheet room design. We went with in-wall speakers and subwoofers, selecting them from a provided short list of well-engineered speakers capable of meeting rp-22 metrics.
Once speakers were selected, the seating positions and room were designed around them.
The speakers and subwoofers and room etc are viewed as a "system" in our case. Many others must work to shoehorn new speakers into an existing room, or an existing room retrofitted with existing equipment.
It always starts with constraints from the room, listener and source material (+signal processing (yes, a room is also a signal processor); amplification needs...). Eg. if the design requires on-wall, you find the best way to mitigate problems - wide baffle, large roundovers, etc. If it needs to be a surround speaker, with some patrons sitting very near and some far away, you must use appropriate solution - an array type speaker. An elegant solution is to find the cheapest part that meets your criteria without many bad compromises. Engineering in a nutshell. Or throw money at the problem.
I my view the set up in your room always need to be adapted. Some speaker with good spinorama measurement will be easier to set up, but where you put the speakers and where you sit will still have a big impact on what you hear.
The size of the room will also impact the size of the speaker/bass extension you will be able to use.
A speaker with worst measurements will be more difficult to set up, might necessitate bigger compromise.
