Yes to all the amp stuff but if the room is robbing the bass the new amp will do very little to help and better DSP might help.
I really appreciate your input. I honestly struggle to understand how drops in impedance fit into this equation. But I gather that it means more current is needed to maintain the same power, and therefore more robust amps, better engineered to deliver that added current, perform better. Better deliver of current might be associated with more powerful components, but it's really its own spec. I can write those words, but I can't say I really get it.If your Onkyo is not clipping, and you are not running out of volume - which you suggest you are not - then you are not using all of its available power (100W @ 8Ohms). Getting another amp with more power won't help since you don't need and won't use those extra watts anyway.
However, some members have noted that your Revels can dip down to 4Ohms and they also note the possibility of increased distortion from your Onkyo (although you don't hear anything).
It might make a difference to try an amp that is stable with more difficult loads - have a look at the review section here and focus on that rather than additional power. It just so happens that you will probably end up with more power too, but power alone is not what you appear to need.
but also the room. A purchase of mic and free download of REW may give much more insight.My takeaway will be, I should not solely be interested in more power,
I'm curious, though, what's your take on the points I made to ppataki about how a more powerful amp could improve sound even at lower volumes?
Transient response has to do with the frequency and phase response of the amp - typically these are flat as a board in the audible range, so not really a thing.
- Better transient response
- More headroom
- Greater dynamic range
- Better "control"
Totally agree. I'm only at this step of evaluating my system because I've already done room EQ using REW and a measurement mic.but also the room. A purchase of mic and free download of REW may give much more insight.
Have you tried tweeking Onkyo's AccuEQ Room Calibration and Phase-Matching Bass Boost and rerunning REW. Sorry should have read that you did some already.Totally agree. I'm only at this step of evaluating my system because I've already done room EQ using REW and a measurement mic.
No, I've only used the Onkyo EQ for my 5.1 system, which uses the Revels as front L and R. For 2.0 music, I created my own filters using a UMIC measurement mic and REW software, then plugging those files into Roon. I'm not sure how to run the Onkyo system on my 2.0 setup without overwriting the 5.1 setup. I also have more confidence in the UMIC/REW combo for setting up the filters, but that could be wrong.Have you tried tweeking Onkyo's AccuEQ Room Calibration and Phase-Matching Bass Boost and rerunning REW. Sorry should have read that you did some already.
Curious, why aren't using a 2.1 for listening to music. Set the Onkyo to 2.1 run REW and use Roon to improve the LF. That will be your music setup. Sorry if I missed something again.No, I've only used the Onkyo EQ for my 5.1 system
Three reasons: (1) My subwoofer is not of especially high quality (though it seems fine; just not super powerful or deep); (2) I figured the Revels had enough low-end for me; and (3) I've never really thought of seeing how well that might work. It's a good suggestion. I will find a time to figure out the Onkyo 2.1 setting, run the filters, and see what I get. Thanks!Curious, why aren't using a 2.1 for listening to music. Set the Onkyo to 2.1 run REW and use Roon to improve the LF. That will be your music setup. Sorry if I missed something again.
Stereo on your music button gives you LF, RF, & Sub. I have just a 10" sub and an older Onkyo too. Looking to upgrade soon. Good LuckThree reasons: (1) My subwoofer is not of especially high quality (though it seems fine; just not super powerful or deep); (2) I figured the Revels had enough low-end for me; and (3) I've never really thought of seeing how well that might work. It's a good suggestion. I will find a time to figure out the Onkyo 2.1 setting, run the filters, and see what I get. Thanks!
From amir's test, looks like they go below 3.5ohms around 95Hz combined with a sharp phase shift there. An AVR will not get the best out of them:A question for those wiser and more experienced than me, on improving the sound from my Revel F208s by possibly changing amps from a relatively inexpensive AV receiver to a quality class D 2-channel stereo amp.
I've placed the speakers carefully and used REW and a measurement mic for room EQ. Currently the speakers are driven by an Onkyo TX NR686 AV receiver. Not exactly an audiophile component, but it drives the speakers to more than adequate volume, and generally sounds good. Here are the specs from Onkyo's website:
My question is: how much audible improvement, if any, would I hear in my system if I used an amp switcher to play music files through a dedicated class D amp in the $600 - $1000 range, like maybe one based on Hypex or Purifi components? I would still use the AV amp for TV.
My subjective experience with headphones is that the bass noticeably fills out with more power, independent of volume.
My hunch is, the decreased distortion of a better amp would not be very noticeable, but the increased power well might be. I mostly, but not exclusively, listen to classical music FWIW.
Thoughts welcome on how best to spend my audio budget. I fear the wait for <$1000 AV receiver with quality amplification could be a very long one.
From amir's test, looks like they go below 3ohms around 95Hz combined with a sharp phase shift there. An AVR will not get the best out of them:
Do the right thing and go Class AMichi X3 is a beast at a relatively reasonable price.
Thanks again. What would be your opinion of the Hypex NC502MP 2-Channel at 500W, which would be a third or more less expensive than the Purifi? I would guess that most any added distortion, as compared to the Purifi, would be swamped by factors relating to the room, the speakers themselves, etc., no?First, your Revel is not critical to drive for the amp. So you may pick what you like. Purifi is a state of the art amp and can drive any speaker, Buckeye seems to deliver good work. The price is very reasonable, you might get a more expensive looking amp for 5-10x the money, but no better one.
The 2-channel Purify should be able to drive your speaker to the limit, so I would go for this one.
If you want more, maybe later, get a second one and Bi-amp your speaker, IMO better than using mono blocks, but I think you should be satisfied even with just the 2-channels.
I would just ask Buckeye. They have stated that there isn't an audible difference in this comparison of an NCoreX vs Purifi Gen 2.Thanks again. What would be your opinion of the Hypex NC502MP 2-Channel at 500W, which would be a third or more less expensive than the Purifi? I would guess that most any added distortion, as compared to the Purifi, would be swamped by factors relating to the room, the speakers themselves, etc., no?
audiosciencereview.com
