hi
ufx 3 is an usb 3 audio system.
if it's a real usb 3 port perhaps you will have better performence with low buffer size for playing vst plugins and instrument.
if you can work at 64 samples or 32 samples with your Fireface 802 without clics and pops stay with it.
optimise your os for low latency, update the firmware if it possible, use the best port for audio performence : usb or firewire.
total mix is compatible with your the 802.
i don't think there will be a huge difference with the sound between this two interface.
