I got a pair of nearly 50 year old Yamaha speakers a while ago, they had been stored in a shed in rural Oregon for over a decade. They cleaned up just fine. I measured them and compared to Yamaha's detailed measurements in their extensive documentation. The tweeters measure very close to the original spec. The woofers both play fine, even though I don't have original Yamaha measurements. The woofers certainly match each other. I even removed one of the crossover electrolytics, it tests as it should so I replaced it.I own speakers that are pretty old - some are 25 years old and the newest one is perhaps 20 almost
What parts degrade?
I know the foam surrounds will go first. In fact, the foam surrounds on my speakers cracked and I replaced them with new drivers from B&W. The surrounds on the ones I have not replaced seem a bit less flexible - I think the gray foam is more prone to rot than the black one.
I know electrolytic caps can also degrade over time but I'm not sure my speakers have them in their crossover.
What else can go bad? Drivers generate heat (didn't know that until recently)- do bass drivers get bad over time?
And when do you decide to upgrade? I was watching a review of a speaker from the same series that's 20+ years old and it was holding its own against newer KEF models.
Should I just replace all the existing midrange drivers?
They are certainly very high quality speakers made from beautiful marine plywood cabinets, and high spec drivers. They sound odd due to Yamaha's bizarre thought process at the time about sound reproduction. But aged nicely, they play classical music for my mom and her dog in her bedroom so they make me happy.
As mentioned, ferrofluid can turn to tar. Seas (for example) made many tweeters back in the '90s with ferrofluid that dries drastically, I have a pair of Seas Excel tweeters with the fluid turned to the consistency asphalt. My more modern units from them seem to age better.
I have several vintage speakers and enjoy them, even the ones like the Yamahas that never sounded very good.
