Lets poke a hole in another myth "doubling down" is not really needed it does not affect the amps performance within its limits .
Some less informed seems to think an amp that does not double down loses dynamics or compress dynamically or is nonlinear within its useful envelope . There basically a current limit a voltage limit and a thermal limit untill you "hit" a limitation the amp is linear and works fine .
You can run around like crazy in your room untill you hit a wall
the non doubling down amp moves some of the walls a bit closer . But if your amp is powerful enough anyways you wont suffer any consequence. IMO is the usual marketing scheme when you take a kernel of truth and stretch it beyond its applicability .
