DVDdoug
- Joined
- May 27, 2021
- Messages
- 5,688
- Likes
- 8,356
A rumble filter or maybe a subsonic filter.(I remember old receivers had some kind of filter especially for that).
Help me remember how it's called....
Hey Doug.A rumble filter or maybe a subsonic filter.
Do you want me to get Andy? DR= difference between quietest and loudest part in recording. In perspective +12 dB pay twice as loud. For tango you need two (DR 12) if it's complex three (DR 18) and if you want to go four times the charm THX cinema (JBL big boys to large hall DR 24). For music it's far more about THD and things with DR over 16~17 are quite rare. Even DR of 9 is fine for something not overly complex problem are over compressed materials with DR of 6~7 and less. THX whose never really ment for home use for many reasons.How much bass is necessary?
I believe to be THX certified, a sub must be able to hit 115dB reference level peaks with minimal distortion and be flat to 20Hz. CEDIA’s RP22 guidance for Level 4 recommends capability of 123dB at 15Hz total system SPL at the RSP with no perceptible distortion or mechanical resonances. This will almost always require multiple quality subwoofers properly placed in a room. Some say these standards don’t go far enough to address infrasonic bass.
Individuals may rightly decide this level bass capability is not necessary for them, but the above standards are worthy targets IMHO.
That's why I like EBU R128 like broadcasting solution as it has to the margin of error (23 LUFS ±1) space even for THX to fit in to real 0 dB from desired program SPL.
To DR up to 20 and taking into consideration you won't go over reference calibration point +20 dB to it. If it's to DR up to 24 dB then +24 dB all to listening point/area of course. If for some reason (high ambient noise for example) you want to go over calibration point (85/88 dB white noise mono/stereo) ELC starts going in opposite direction slightly reducing bass. So it's 108~112 dB max to calibration point as low as it can follow I still think it's better to low self (as high pass will be taken already) sharply sub's at 25 Hz then let them go below of that (priorities THD there). Most folks don't understand that creating pressure chamber equilisation also ruins totally decay times for standing waves and then they impact main bass ritam section (simply staying above it or mixing with it) and this is much more important area as it well brings ritam/bit part.My answer to “How much bass is enough?” was given as a general response, not necessarily specific to the OP, or someone listening to just stereo music. Although, my answer seems to fit well to the extreme low end required in the charts and graphs you posted in posts #35 & #36, so maybe we aren’t far apart in our views? I agree with you on the DR and THD. The system needs to be robust enough to handle dynamic transients, and nobody wants sloppy, distorted bass at any SPL. Unless the OP is listening to Curtain Shaker all day, they won’t need bass capabilities to the level I suggested, but it gives me a measure of comfort knowing my system is capable of it for movies and music. The suggestion of at least two subs was driven more by delivering a smooth bass response in the room and countering nulls with placement.
Yes, I understand what you're talking about, it makes sense when I get a better subwoofer(at least 12 incha or two 10')So you need a high pass at 75 Hz (or 80 Hz to relax them a little bit) 24 dB to deal whit what ever is upsetting woffer's at 57 Hz
They are rated to - 6 dB of what port gives in ideal conditions and you aim at - 6 for Linkwitz Riley crossover but you aim to what woofer gives alone disregarding and pluging the port all together. For Butterwort you aim at - 3 and try to do it lower order (dB slope down) it's very important that end result corresponds to math model as much as possible and PEQ is saving grace to achieve that in crossing area and beyond it so it stays autended and can not interfere with what driver above is doing. When sub's leak in vocal area let's just say that doesn't sound good. Stressing out is when you cut speaker woffer to above what it can do max on it's own and make sweet spot for crossover where you want it. It doesn't struggle nearly as much after that pulling hard to what's difficult for it substantially rising output capabilities above that point or lowering THD there. Not very easy to do but menagable.Yes, I understand what you're talking about, it makes sense when I get a better subwoofer(at least 12 incha or two 10')
Now when I crossed them at 70 and above(60 is too low,I get a big hole in that range.
End that is with ports,go figure?)They are rated 42-2000Hz but that must be -10db anechoic?
I get this experience
"Just bought a set of KEF R3 Meta, and they sound just fine, but quite "thin" at the mid-bass are. My DIY speakers with a pair of Satori WO24P per side, sound just as smooth and refined, but with much more volume - making them sound more powerful, but not in the typical "more bass" kinda way - no boominess - though more "full".
So IMO, we have to take the specific "picture" into consideration. The room, the setup, max SPL, the reference, the preference and the measurements.
I also "add" a little extra in the deep - below around 50Hz - since I like that "thumb" it adds to the sound.
Response is not super "clean" - because that is just all the "fun" my room adds to the output.
My room is strange.It is a small two-room apartment of 50m².So it's 108~112 dB max to calibration point
So ideally there would be two nice 10 inch subwoofers next to each speaker (2.2), and crossed at 120HZ and some EQ.Stressing out is when you cut speaker woffer to above what it can do max on it's own and make sweet spot for crossover where you want it. It doesn't struggle nearly as much after that pulling hard to what's difficult for it substantially rising output capabilities above that point or lowering THD there. Not very easy to do but menagable.
