ZolaIII
- Joined
- Jul 28, 2019
- Messages
- 5,727
- Likes
- 3,428
@Marin vocal range is 250 to 1000 Hz, 4000 for overtones to second harmonic. I can't find trustworthy full F5 measurements. What I did found will be enough (hopefully) and it's bad.
Let's start with frequency response plots from Sound and Vision.
F5 is purple, B5 is red it's same woofer and shows how little does the two additional one's on F5 crossed at 100 Hz. S10EQ blue line (close up measurements) is there to give you idea how you should cross F5's without high pass. I don't know where you diged bad looking Linton's plots we tend to use Spinorama for what's available. Yes crossovers should/could be lower for 8" woofer which would contribute to cleaner mids at the bright side mid range woffer is crossed at 2.4 KHz which is still high but difference is huge to one crossed at 3 KHz on F5 and it sure shows.
Sensitivity= SPL @ 1 W 8 Ohms from 1m.
Where on earth did you find subjectivist fairytale about cabinets on Serb-Croatian? I am really interested to hear that. Unfortunately as suspected cabinets are bad which somehow is usual for such cheaper flour stand speakers.
Lot of cabinet refractions as you can see.
It whosent about how much successful Andis speakers cost or good ones from competition it's about how this ain't one of those. In that regard E DBR62's stil hold their place for history and text books how much is achievable for minimal money. F5 SMPR regular price whose 850$ but you could buy them for 500$ new. Mentioned Linton's can be bought with stands for less than a 1000$ and without the stands for as little as 650 and for what you get that's pretty stellar. It's called YPAO loudness when it comes to Yamaha.
Now as you like them so much at least first picture gives you idea how they should be crossed without high pass (low self when it's a Yamaha) with a deacent sub. If you ask me it whosent your best purchase.
