90dB transient peak at the MLP would be ~70-75dB average, on well mixed, dynamic material.
90dB average at the MLP would be almost unbearable to most listeners in normal rooms and peaks could go as high as 110dB.
You really should make some tests with a calibrated SPL meter. You'd be surprised.
BTW: just because your speaker has 83dB sensitivity does not mean you get 83dB with one watt on your couch. Each doubling of distance loses you 3dB. So at 4m distance you already lost 12dB and are now at 71dB SPL. Your amp needs to make up for these losses and that means you need 16W (each doubling of amp power gets you +3dB SPL) to reach the 83dB. Add in peaks with another 15dB and you are already at 512W for guaranteed clip free playback even on transient peaks of well mastered, highly dynamic material.
As for listening fatigue: a lot of factors go into that. Distortion, spectrum, volume, bode plot of your ears, characteristics of the room...
It's a complex thing and highly personal. Even state of mind plays a role. Sometimes I get fatigued super quickly, sometimes I can listen for hours. Same system, same music, same room, same volume.
I can empathize.
I can't go much past 100dB Z-weighted transient peak. Just sounds shrill to my ears. No matter if uber expensive headphones or well made speakers.
My ears just don't like the treble/mids.
I was surprised measuring my speakers at my listening position with the UMIK-1.
The combination of two speakers and room gain, yielded the speaker sensitivity rating of 86 dB at my seating position.
I suspect that this may be true in many cases.
The Revel Salons2s produced 86 dB at 2.83 volts (with 0 dB full scale 1 and 2kHz tones).
Since these are basically 4 Ohm speakers, that requires about 2 watts.
This makes sense since is room gain and two speakers. That seems fair given that no one is listening to one speaker.
The processors volume was at -31.
With digital sources, it is simple to compute the maximum volume setting that will NEVER clip.
This calculation indicates that source that reach 0 dBFS driving the Salon2s could clip with the volume set to -10.
Perhaps this is not loud enough for all sources, but I have not found that to be an issue.
Using Sarah McLachlan's "I Love you" as a clip test, the meters, the bi-amped AHB2s clip never clip at -8. The ATI6000s bi-amping never clipped at -5.
The AHB2s produce about 200 watts into 4 Ohms and the AT6000s produce 450 watts into 4 Ohms, about 3 dB.
This is extremely loud, in both cases, something I would only do for a clipping test.
Since doing this experiment, I have noticed the volume levels playing ATV4K HT (Salon2 front/rear and Voice2) vary wildly.
Some requiring -27 for clear dialog down to -6.
Theoretically, the AHB2s could clip at -6 but I have never seen this occur.
Things get pretty loud playing 5 speakers and two dual-12 inch Rythmik subwoofers.
The AHB2 has sensitive clip indicators and will turn off at about 1% distortion so there is little concern for speaker damage.
I have a greater concern for ear damage.
- Rich
