Was -10dB by sitting 3meters away included?
Thanks
Yes and room gain because it is measured at the listening position.
I measured 0 dBFS sine waves at my listening position in stereo with the XMC-1 set to -31 which produced 2.83 volts (measured with a Fluke 87 multi-meter). Since the Salon2's are basically 4 ohms, this computes to 2 watts. From there, I created a spread sheet that includes my typical listening levels, the XMC-1 volume setting, and the maximum power for a digital signal (excluding inter-sample overage).
You can view the spreadsheet in this post:
https://www.audiosciencereview.com/...mplifier-power-is-required.10781/#post-300381
I also compared my computations to this power estimator (
https://myhometheater.homestead.com/splcalculator.html )
that includes room gain and speaker count in this post:
https://www.audiosciencereview.com/...mplifier-power-is-required.10781/#post-300476
The calculator computed 104.9 max at 180 watts (rated value for the AHB2 into 4 ohms) versus 128 that is based on in-room measurements, that is approximately a 1 dB difference.
So even with maximum gain in this calculator, it is computing a bit more power required.
The AHB2's include clip indicators at 1% and these illuminate at levels corresponding to my in-room measurements.
With digital sources, the maximum signal 0 dBFS so power estimation is better than analog.
All of my sources are digital.
If you have a multi-meter, an SPL meter, and a spreadsheet you can perform your own analysis in your room. It's good geek fun.
- Rich
