And more depending on where the speakers are placed:Don't forget the second speaker (+3dB), and room gain, which can be another 3dB too.
That's not insignificant because it can mean the difference between 125 and 500W for example.
www.audiosciencereview.com
Well if you say "house", I'm assuming a rather large listening space and moderate distance to the speakers.Not once have I ever said to myself "that's more power than I need"
Thank you, @tineared, perhaps you need Avantgarde Acoustic Duo Horn Speakers (106db/1W/1m) or w/omega (110db/1W/1m).A few decades ago I bought a Parasound HCA-3500 that puts out 350W@8 Ohms. It's driving a pair of 6 Ohm NHT 3.3s at an 87dB sensitivity in a medium sized room.
I enjoy listening to concerts in my house when the spirit moves me
I want to replace the amp with a Hypex NCx500 because the Parasound is huge and has become too damn heavy (80lbs) to move gracefully, but it just won't die
I'm from the Tim Taylor school of thought with regards to amplifier power
Since you brought it up, I intend to bi-amp them as I have in the past. Those magnificent Tonegen 1259 woofers are capable of some serious air movement, but they're quite hungry. The HCA-3500 will feed the woofers and I have a Parasound A23+ (160W@8 Ohms) for the 6.5" Tonegen midrange and SEAS 4" upper-midrange and 1" tweeter. Good times...Well if you say "house", I'm assuming a rather large listening space and moderate distance to the speakers.
350W may even be on the insufficient side, regarding transients, if you listen at live concert levels.
Thanks for the suggestion, but I'm quite happy with my 3.3s and also my wife. The Avantgardes would not blend well with the room's decor and I suspect would have zero WAF.Thank you, @tineared, perhaps you need Avantgarde Acoustic Duo Horn Speakers (106db/1W/1m) or w/omega (110db/1W/1m).
For Consideration/Discussion, lets look at the Power/W of the Parasound HCA-3500/350W@8 Ohms with the Avantgarde Acoustic Duo Horn Speakers w/omega (110db/1W/1m) compared to the NHT 3.3s (87dB/1W/1m)....
SPL Calculator .... let me know, if the calculations require correction :=)
- 110db (1W/1m), for 350W (at 3m, 350W would sound like 128.9db).... Avantgarde Acoustic Duo Horn Speakers w/omega (110db) & Parasound HCA-3500/350W@8 Ohms and fill an extremely large room/building but for 350W/110db/1m/1W, will easyly fill a room to 85db/@3m and require about 0.05W (128.9 - 85 = 43.9db)
- 107db/175W
- 104db/87.5W
- 101db/43.75W
- 98db/21.875W
- 95db/10.9375W
- 92db/5.46875W
- 89db/2.734375W
- 86db/1.3671875W.... NHT 3.3s (87dB) for 350W (at 3m, 350W would sound like 105.9db)
- in Comparison the Parasound HCA-3500/350W@8 Ohms would be like 1.8W but for 350W/87db/1m/1W, will easyly fill a room to 85db/@3m and require about 3W (105.9 - 85 = 20.9db)
- Note that it is assumed that the speakers are 8ohms (nominal) and easy to drive.
I don't see the point.Since you brought it up, I intend to bi-amp them as I have in the past. Those magnificent Tonegen 1259 woofers are capable of some serious air movement, but they're quite hungry. The HCA-3500 will feed the woofers and I have a Parasound A23+ (160W@8 Ohms) for the 6.5" Tonegen midrange and SEAS 4" upper-midrange and 1" tweeter. Good times...
Thank you, @tineared, considerations for an Amplifyers Speaker Load, especially for 1/2/4R (even 8R) (minimum) Speaker Load....Thank you, @tineared, perhaps you need Avantgarde Acoustic Duo Horn Speakers (106db/1W/1m) or w/omega (110db/1W/1m).
- 110db (1W/1m), for 350W (at 3m, 350W would sound like 128.9db).... Avantgarde Acoustic Duo Horn Speakers w/omega (110db) & Parasound HCA-3500/350W@8 Ohms and fill an extremely large room/building but for 350W/110db/1m/1W, will easyly fill a room to 85db/@3m and requires about 0.017W* (128.9 - 85 = 43.9db, 43.9/3=14.33, 350W/2**14.33=0.017W).
- The Parasound HCA-3500 would need to be almost no Noise/THD, high SNR/db, no Masking, at this very low volume/amplifycation, wouldn't it, and that will/would include the Devices feeding/connecting to it, won't it?
- A Preamp/Closed Loop, with low Output impedance (<=0.1R, allow (Loading) Headroom), outputs 2/4/7 watts (allow (106/110/112db Listening@3m Headroom), plus 2x Lineout for the Subs, could possablely/easyly drive these, couldn't it, for consideration?
- Note for consideration....
- (Reference @Sokel) for 120db SPL and Listening@3m, now a 45W Amplifyer (nolonger a Preamp) is required where 120db SPL (capablety) is required to ensure that Dynamic Peaks/Chest Punch are delivered well (no meh)/without Cliping/for Listening@3m.
- (Reference @dlaloum) your Amp/Speaker combination needs to be able to deliver at least 20db above your Listening Level (75/85/95/105db/your choice, for your distance from the Speakers), to ensure that Dynamic Peaks/Chest Punch are delivered without meh and/or cliping :=)
- How do you workout 20db/Listening Headroom, perhaps this is reasonable (let me know?).... 87dB speakers, 3m/Listening Position, 85db Listening Level
- Amp, to easyly fill a room to 85db@3m requires about 2.792W (3W amp can do this, can't it?)
- 105db@3m, 20db/Listening Headroom, requires about 285W (300W amp can do this, can't it? For @tineared's amp/350W/8R, he knows exactly what he is doing, doesn't he, and hopefully his amp will cover the Speakers Impedance below 8R (amp/speaker specs will/should reveal)?
- To clarify, use the SPL Calculator
- 107db/175W
- 104db/87.5W
- 101db/43.75W
- 98db/21.875W
- 95db/10.9375W
- 92db/5.46875W
- 89db/2.734375W
- in Comparison the Parasound HCA-3500/350W@8 Ohms would be like 1.8W but for 350W/87db/1m/1W, will easyly fill a room to 85db/@3m and requires about 2.792W* (105.9 - 85 = 20.9db, 20.9/3=6.97, 350W/2**6.97=2.792W)
- *Note that it is assumed that the speakers are 8ohms (nominal) and easy to drive.... for consideration
- 10R/ohm Speaker (minimum) Load, requires about 2.34W.... notice that it is not half, why, Hint.... Voltage reference is 8R, V=√(P×R)
- 8R/ohm Speaker (minimum) Load, requires about 2.792W
- 4R/ohm Speaker (minimum) Load, requires about 5.584W
- 2R/ohm Speaker (minimum) Load, requires about 11.168W
- 1R/ohm Speaker (minimum) Load, requires about 22.336W
- where using the same voltage, P=V**2/R, because we know P/R we will know the V (in this case/above, assumed to be the same), won't we?
- Considerations for an Amplifyers Speaker Load, especially for 1/2/4R (even 8R) (minimum) Speaker Load....
- V/Voltage Invariant/Independent.... that is, regardless of Speaker R/Load, that the V does not drupe/sag, so that the Speaker sees a Constant Voltage Source.
- I/Current no Limit.... that is, regardless of Speaker R/Load, that the Amps I/Current is not Limited and the necessary/required I/Current is (instantaneously/no Lag) delivered to the Speaker.
- Output Impedance.... that is, for the above to work well, the Amps Output Impedance must be at least 1/10th (1 Decade, preferablely more/lower) lower than the Speakers (minimum) Impedance.
- Note that Capacitive Speaker Loads are another matter, aren't they? It would be nice to read yours or others discernment of Capacitive Speaker Loads, please do so, thank you :=)
Nope.Much easier to just accept some inaudibly clipping transients.
Really depends on the material indeed.Nope.
Seriously now, a personal calculation for the reference level gets reasonable results, for as with classical for example peaks are everything.
Same with rock as I suspect, as the measly 3db is what sometimes separates the chest punch to meh...
Power is easy and dirt cheap these days.
I agree that any improvement will be minimal, but it costs me nothing to implement as I already have all the gear so there really is no down side. The system is not currently underpowered as it plays far louder than I need (>110dB) or want and I never hear any indication of clipping.I don't see the point.
Wattage difference is too low, you won't notice that in practice. You're basically going from 350W -> 510W per channel, assuming the tweeters/Midrange even need that kind of Wattage. Your 350W amp feeding the woofers may clip long before your midrange/tweeter amp reaches capacity as most energy in music is usually in the bass.
Remember: doubling the amp power gives you a measly +3dB SPL.
E.g.:
350W = 110dB
700W = 113dB
1400W = 116dB
2800W = 119dB
If you really want some noticeable change, you'd need to give the system 3KW+ per channel, which would result in +9dB.
Though it begs the question whether you speakers (or your ears) would be able to handle that much power.
As you can see: amp power demands get ridiculous very, very quickly. Much easier to just accept some inaudibly clipping transients.
Thank you, @Sokel, intrigueing, is this to do with Amplifyer and/or Speaker considerations, other than Amplifyer Power (as Titled), or are you suggesting that Amplifyer Power is everything?Seriously now, a personal calculation for the reference level gets reasonable results, for as with classical for example peaks are everything.
I would take mains, control room monitors as a good example.Thank you, @Sokel, intrigueing, is this to do with Amplifyer and/or Speaker considerations, other than Amplifyer Power (as Titled), or are you suggesting that Amplifyer Power is everything?
Re reference level.... if you do not mind, could you clarify what 'reference level' means, thank you :=)
Thank you, @Sokel, Ah, re reference level/calculation....I would take mains, control room monitors as a good example.
You can take a look at the power they are using to achieve the desired. Smaller active monitors as well.
About reference level, the norm is the THX standard which requires 85dB SPL with 20dB of headroom with reasonable low distortion, at least, with the THX Certified Dominus performance reaching 120dB SPL.
The above is not written to stone of course and we all must take take of our hearing, follow the instructions, etc.
Reference level is defined in the Dolby / THX / DTS standards, as a signal at -20dbFS being reproduced at the listening spot at 85db (theatre standard) or 75db (domestic / home standard).Thank you, @Sokel, intrigueing, is this to do with Amplifyer and/or Speaker considerations, other than Amplifyer Power (as Titled), or are you suggesting that Amplifyer Power is everything?
Thank you, @dlaloum, Yes, your Amp/Speaker combination needs to be able to deliver at least 20db above your Listening Level (75/85/95/105db/your choice, for your distance from the Speakers), to ensure that Dynamic Peaks/Chest Punch are delivered without meh and/or cliping :=)Reference level is defined in the Dolby / THX / DTS standards, as a signal at -20dbFS being reproduced at the listening spot at 85db (theatre standard) or 75db (domestic / home standard).
Movies are always recorded to this standard - which then allows for proper calibration of listening spaces / theatres to accurately reproduce the recording as per the mastering engineers wishes.
As the reference signal is at -20db and the digital recording maximum is 0db, to reproduce the entire gamut of dynamic range, including peaks, you need 20db above reference as your peak capability.
So in a home you need 95db, and in a movie theatre you need 105db
Note that the reference level for the Low Frequency Effects channel (sometimes erroneously called the "sub" channel) - is 10 db higher - so base level in home for LFE is 85db and peak 105db, and for theatres 95db with peak 115db.
Depends on the speaker, really. Though 120dB is kinda whacko.Power is easy and dirt cheap these days.
Please take into account that SPL decay in the closed room is different from the free space. In free space, it is -6dB with doubling the distance. But in a furnished room, it would be typically only -3dB.. That is in a nearfield setup at 1m.
If we increase the distance to the typical 3m couch listening, we're at 2500W for transients
Isn't this "less decay" identical to room gain in principle? The damping properties of air is the same, the big difference is reflections and kinetic energy having more difficulty leaving the place.Please take into account that SPL decay in the closed room is different from the free space. In free space, it is -6dB with doubling the distance. But in a furnished room, it would be typically only -3dB.
