is there any advantage to positioning the subs off the floor, say, at ear height or maybe a bit lower? Does anyone do this?
I have in the past - higher than ear level, well above the room centerline. (On top of a tall bookcase.) The sub I used was objectively terrible but suitable for purpose. It substantially smoothed the height mode in that room. Downside is manual calibration is required - DLBC is not (yet, I hope) designed to integrate subs of wildly disparate capability.
I had a shelf in our current home wired to allow a high sub as well. The space is limited, only 11” tall and 11” deep but fairly wide. While I have not implemented anything there yet, my thought was at some point to add a very thin sub (4”-5” deep) with 4x Aura shallow 8” woofers.
To answer the OP, main system currently uses 3 subs:
1 18” in an ~80L closed box (front corner)
2x 15” in an 80L closed box (other front corner)
2x 12” dual opposed in ~65L closed box (right next to main seat)
All AuraSound underhung coil neo radial motor drivers, 1250W (Crown DCIn) each.
Front subs are integrated into cabinets, 3rd sub used as end table.
DLBC’s best blend is at 75Hz I think, which is much lower than my default (I start at 120Hz and adjust from there) but I go with what works over dogma. I may add another sub or 2 (height, shallow sub under left wall) to try to reduce the spread in the next octave up. It’s a daunting idea because it means going back to manual subwoofer system setup and treating them as a single unit in DLBC. That’s a huge time sink.
Desktop system uses two small closed box subs (~18L each) with Aurasound NS10-794-4a, powered by an old D-Sonic amp (2x Icepower 500ASP). One would suffice but I have 2 and it does not hurt to use both.
2-channel system is a work in (slow) progress. Sub units are set but exact setup is not.
-two “boundary subs” in front corners (SB Acoustics 8Ω shallow 10” woofers in 6L closed boxes in the front corners powered by Crown XLS2502 run in stereo)
-Tymphany LAT-700 in ~35L closed box centered on front wall (integrated into media cabinet) powered by Paradigm X-850 (ARC not used)
-JL Audio E110 in back corner
[edit: nearfield subs, 2-channel sub amplification]
