For those of you who think that just because you have full range main speakers so you don't need subwoofers, you are wrong because:
1. Adding subwoofers will smooth out the bass response since you have more bass sources in the room;
Counter argument - having 4 or 6 full range speakers in your setup (ie: the base layer of a surround setup) provides you with 4 or 6 sources of bass, resulting in much more even response through the room...
2. It sounds different. My speakers are capable of going flat down to 20Hz. I did an experiment where I equalized the main speakers alone down to 20Hz. And I made another filter where the mains + subs play together and equalized to the same target curve. I made sure the filters were level matched in DSP, and proceeded to listen. The version with the subwoofer sounds noticeably different. It has way more power and authority without sounding unbalanced and tubby. It's something you have to experience to understand.
So in objective measurement terms - are we talking about peak SPL capabilities? (that is my interpretation of what you are saying)
The interesting thing about using Dirac ART for its bass management, alongside full range speakers, is that the low frequency peak SPL capability becomes the sum of the bass capable speakers (obviously within their frequency range! - which may be short of 20Hz)
Hence even if the bass capability of a single speaker might fall short of the peak demands, having four speakers, should boost peak capacity by around 6db (or the equivalent multiplying amp power by 4...)
Those of you who have heard a pipe organ will know that it is an overwhelming experience. Even when the SPL is reasonable, the air in your chest vibrates and you can feel the sound. If you don't have subwoofers, forget it - you're not getting that sensation at home.
lol - I am not even going to try to replicate a pipe organ at home....
Having said that - switching from a Dirac Live setup with 4 full range base layer speakers (fronts down to 24Hz and surrounds down to 35Hz - all at -3db, and set up for "double bass" so LFE is also reproduced by full range speakers), to my first experiments with Dirac ART... I am finding that I have moved from a Target curve with +4db in the bass to -3db at the high extreme, to a target curve with +0db (ie: flat) in the bass, and -3db in the highs.
As you can tell I am by no means a bass head!!
Yes I do have a single sub in the setup... (24Hz -3db)
Sound is very even across the listening space, listening to stereo (but with all "support" active) - Imaging is good, midrange is very good... not sure whether it is better than the previous Dirac Live config - I am not experiencing a massive improvement in the bass - but the overall soundstage has expanded.
(keeping in mind this is my first try with Dirac ART... and I was time constrained by family "space invaders" cutting short my tweaking time)
In Movies, right now I am not hearing a substantive difference in my ART setup, vs my previous DL setup...
In Stereo Music - I feel like there is an expansiveness to the soundstage that wasn't present before
(My listening room is a very large open living/dining/kitchen with a vaulted/cathedral ceiling - so it tends not to suffer from major bass node issues... less for ART to fix?)
