I recently purchased some Neuman KH310 and have been working to set them up mid-field in a medium size wonky room. In addition to the KH310 I had 4 subs (2 large DIY QTC 0.707 sealed and 2 SVS SB-3000) and a 10 channel interface and a PC and REW and a good MIC and have been spending some time playing around with different combinations including playing the subs in isolation to see what exactly they are doing. I have learned a lot and I mostly don't like the answers.
1. Sub integration, especially with "modern" small enclosure heavily DSP's speakers and subs is very difficult. The "old school" DIY sealed sub with almost no group delay and smooth roll off is the good citizen in the group. The SVS subs with 125 ms group delay, 6+ ms DSP delay, and strong pre-ringing, even though the specs look good on paper, is a big problem and if I knew what I know now and I would not have purchased them. I also tried DIRAC DLBC and it failed miserably unfortunately.
2. For moderate level listening the KH310 play very nice by themselves. At moderate levels even with material with high bass content the SVS subs that I have crossed low do little or nothing audibally. The Fletcher- Munson curve is real.
3. At louder listening levels the DIY subs start coming alive. I have the KH310s co-located with the DIY subs and that combination starts coming into its own at ~75 dB listening level. The DIY's will play down to ~30 Hz with room gain and with the smooth roll off I don't feel like I am missing anything at louder levels. This is in essence like having tower speakers and is a easy practical solution and very enjoyable to listen to for a wide range of listening levels and content.
4. Adding in the 2 SVS subs does not do anything until playing quite loud with music that also has LF content. I test with pipe organ music and the heat beat from DSOTM. In some limited circumstance with the right loudness and content the extra low bass can be exhilarating. Even though I feel like I "don't miss it" with the other combinations when it is there I like it.
5. The most disappointing thing I found is that the small sealed SVS subs don't really put out much SPL below 25 Hz. Because of Fletcher-Munson even 90 dB SPL is not really very loud at 20 Hz. I found that the range where the SVS subs added anything audible down low before they became "overloaded" was small. The rest of the system could easily play louder but the subs could not keep up and when they overloaded they sounded BAD. I much prefer rolled off lows to a failed attempt at the lows. Don't underestimate how hard it is to generate high quality high level SPLs below 25 Hz, it gets exponentially harder every Hz you go down.
My conclusion is 2 near full range well behaved speakers is the most versatile and easy to set up combination and the best place to start. If you are going to add subs then don't bother with the current in style small subs, they are too hard to integrate and they still don't really put out that much LF energy. Go big with big enclosures, big drivers, and big amps.
While it makes no practical sense I did just order an 18" ported sub with 310 liters of volume to see if I can get my pipe organ music to play right.
