Why would one go to the expense of buying a high quality and accurate amplifier if you then deliberately destroy its accuracy because you can't choose and set up the rest of the system optimally without DSP?
As I've said before, I'm not saying that multi-speaker AV/HT systems won't benefit from DSP, but please try to fix problems in 2-channel systems without resorting to the spoiling of the amp's accuracy. If you are relying on DSP to "adjust" the signal such that your ears receive a flat response, why buy good quality amps and speakers in the first place? But I must admit that adding DSP to a poorly chosen or set up system may deliver what appears to be improved sound, so I accept your criticism of my opinion.
Ideally, you start by setting things up as well as possible, obviously within the limitations of the available environment (including those you share it with!!).
You position the speakers (especially L, R and Center) - adjust toe in, distance from wall(s), do what can be done with the room (thick acoustically absorbant curtains can do wonders with the higher frequency reflections), bookshelves are also excellent with rows of books helping too...
Then you look at applying DSP...
Amps ...well yes you want something good, but anything halfway decent nowadays will do the "wire with gain" job.... the key thing with amps is to ensure that they properly match your speakers... if you have easy to drive 8 ohm speakers - great, pretty much anything will do a good job. If your speakers drop down to 1.6 ohm like mine, then the selection is a lot more limited... so yes you need a good amp.
But "high quality, accurate" - very very few amps aren't accurate today... (unless you are into some of the tube or similar designs that are intentionally "coloured"....), and there are plenty of high quality amps.
Amps and speakers alone will not compensate for room effects - proper room setup can make the best of the room such as it is - and thereafter, the options are to change the room (we are talking builders, acousticians, bass traps, other treatments, and $$$,$$$ ), or do the best we can using DSP to ameliorate things (typically $$$ to $$$$).
Most of us live in the budget category that excludes the "change the room" alternative - but can readily access the DSP option.
