Bummer.At one stage, I ran a 4.0 setup using 4 Quad Electrostatic speakers .... it sounded great! But it failed the WAF.... and was ultimately retired in favour of other more "living space friendly" alternatives....
Well it can be for extending your low frequency range, depends what type of speakers you have.I will once again reiterate that subs are not for extending your low frequency range or volume but to smooth out room nodes by taking advantage of multiple sound sources. This is relevant up to about 160hz in most rooms.
FIFYI will once again reiterate that subs are not for extending your low frequency range or volume but to smooth out roomnodesmodes by taking advantage of multiple sound sources. This is relevant up to about 160hz in most rooms.
Anyway, so much of what we hear/like/dislike in our systems .... I really believe comes down to low frequency response....
....how It sets the foundation.
Like Toole and Olive estimate, weighs in at maybe 30% in determining subjective preference.
Must admit, I think low frequency performance's contribution to SQ, is somewhere between 10X-100X more important than electronics SINAD, amp types, yada, etc.
Maybe you didn't use correct info - measurements, etc ?And I know there are those who will always say “ you don’t know what you’re missing until you’ve been more rigorous about addressing the bass performance in your room.” I’ve tried that too, and didn’t find it a revelation.
I think your reference is to 'full range' types, and your assessment is my subjective preference.In practice, having had many different floor[,] standing loudspeakers in my room over the past several decades, I’ve never really had a problem getting very satisfying bass.
Despite the emphasis many audiophiles put on obsessively chasing low, flat bass response with multiple subwoofers, room, correction, etc.
In practice, having had many different floor, standing loudspeakers in my room over the past several decades, I’ve never really had a problem getting very satisfying bass. Without any heroic measures beyond just moving the speakers around. (I have a 15’ x 13’ room and my floor standing speakers tended to range from 25 to 30/35 Hz).
I’m not talking of course about technical perfection. No doubt room sweeps would show some room nodes.
But subjectively, the bass sounded very even and satisfying to me with almost all of my loudspeakers. When there was the occasional obvious node or contribution from the room… it was occasional. Not at all determinative to my enjoying the bass overall.
www.audiosciencereview.com
If you're in a bad room the solution is to move to a house with a good room. That probably means a big room and fairly light weight construction. Wood frame and drywall lets the energy escape. I had a system in the basement of a little brick house. I eq'd the bass to +-1 db. I had a couple dozen homemade bass traps. They made a pretty big difference but it never sounded right. Now I'm in a big room in a house with wood frame construction that lets a lot of bass energy pass through the walls. I measured it and there are still pretty big variances in the bass when measuring a sine wave but I don't notice it with music or movies.Despite the emphasis many audiophiles put on obsessively chasing low, flat bass response with multiple subwoofers, room, correction, etc.
To isolate the bass/ subs role in the improvement...just turn off the main speaker and listen to sub(s) alone. If comparing floor-standers without subs, a low-pass filter to isolate the sub frequencies can be employed.
Sure, multi-sub gets frequency smoother, and makes for a more ambience-type sound, but it loses the raw impact of bass transients that make sound so alive and exciting.
Great bass transients have directionality...the hit in the chest etc. Multi-sub loses that directionality which can be heard outdoors.
Maybe the peakiness and or dips in your in room bass frequency response is actually something you like when you talk about "impact of bass transients that make sound so alive and exciting". But I don't know how many peaks or dips you have in your in room bass frequency response, but you'd probably have some if you're not optimising sub location (and/or not using roomEQ, don't know if you are). Maybe I'm just offering the idea that the things you describe could actually more be attributable to in room frequency response rather than other factors. I used to quite like just letting Anechoic Flat speakers "run free" without roomEQ and yet I know that i had peaks & dips in bass frequency response.What you say makes sense to me.
There's so many issues in play...
First is the fact that subs even exist...separately that is.
Speakers need to have their full bass extension co-located with the speaker, just like the rest of the speakers' low, mid, and high section are.
The crossover between the sub/extended lows and the rest of the speaker is just as important to optimal sound as any of the other crossovers in the speaker.
The need for properly spaced/located acoustic centers between a sub and main is just as important as the placement of the speakers other drivers in its design.
I don't think folks realize the extent of the integration problems, the lobing and summation issues, that are created when subs are physically separated from speakers.
I think mitigating those integration issues is as much a part of what's going on with multi-sub, as is the smoothing out room modes multi-sub advantage so often heard.
Truth is imo, multi-sub is just a technique to blur/average problems out of existence.....problems, of both speakers with subs, and rooms.
The technique works as far as smoothing out frequency response....but it's a time domain nightmare.
Anybody who thinks small-room multi-sub is the best bass possible, simply needs to listen outdoors to their same speakers set on top their subs properly crossed over... stereo or even mono. The bass improvement is always remarkable.
To isolate the bass/ subs role in the improvement...just turn off the main speaker and listen to sub(s) alone. If comparing floor-standers without subs, a low-pass filter to isolate the sub frequencies can be employed. I use what I hear outdoors as the goal for what I want to achieve indoors.
So far indoors, plain old floor-standers with deep bass extension, or mains on top of subs...with time honored attention to room placement, has come closer to outdoors than any multi-sub attempts.
(Imo, we've become smooth frequency & directivity obsessed, in an effort to find what pleases the masses...but I digress.)
Your room was renovated by a professional acoustician, i guess that will also solve your bass respons for the better an because of that a subwoofer will do not much for you than it is obvious you find it not a revelation.
If i'm correct saw you are using Thiel speakers who are build by design phase coherent just like my Vandersteen speakers. Do you hear a difference using these speakers compared to speakers who are not build phase coherent. I do in imaging staging natural voice (limited baffel design tweeters so no or less boxie sound) they dissepear with quality recordings completely and enhanced using DSP. Using also compared to you a mild form of room treatment carpet absorption panels for first (wall) reflections.The room certainly does overall sound better than ever after the renovation (which was done in 2009/2010). And there is a certain amount of treatment for bass. But not as much as it would take to get a room like this perfectly linear all the way to 20 Hz.
When I say, I’ve always achieved satisfying bass response, I’m including all the years before the renovation as well. (Though I might have a bit of a lucky room. I’ve had a couple speaker designers have a listen, and this was before the renovation, and they both said that they were surprised at how good the sound was in the room, generally smooth and balanced. Perhaps it has to do with the particular shape, bay windows, a very large opening in the room to one side into a hallway. Dunno …)
If i'm correct saw you are using Thiel speakers who are build by design phase coherent just like my Vandersteen speakers. Do you hear a different using these speakers compared to speakers who are not build phase coherent. I do in imaging staging they dissepear with quality recordings completely.
The standard, meaning you won’t get hired without one, double bass in an orchestra uses an “extension” on the E string which lowers that string to C (32.7hz). The very common five string electric bass guitar uses a low B string (30.9hz).The lowest note on a double bass or an electric bass is 41hz. My speakers are just barely able to get down that low. That’s good enough for me because the vast majority of jazz and rock groups don’t even get down to 41hz. Rap music, some electronic music and the Saint-Saëns organ Symphony will get down lower than 41hz but I don’t listen to that stuff.
If I’m reading you right, you were suggesting it’s possible I simply may not have preferred even perfectly integrated multiple subs in my particular case. Hard to know.
