How loud do you like your music?
  • Under 70dB
    Votes: 81 19.4%
  • Around 75dB
    Votes: 147 35.3%
  • Around 80dB
    Votes: 105 25.2%
  • Around 85dB
    Votes: 51 12.2%
  • Around 90dB
    Votes: 22 5.3%
  • It has to be over 90dB to enjoy
    Votes: 11 2.6%
I listen to music at low or high volume, depending on my mood and the music.
From what I've tested, up to 90 dB the sound quality is ok, but as the volume goes up, distortions appear and when the volume is too loud, the distortions will be heard louder than the music...
At least that's my feeling from the tests.
It all depends on what type of music I'm listening to and more importantly, the mood I'm in. I think my nominal listening levels are in the 70-75 dB range. I occasionally "crank" it up to 95dB peaks.
When it's 95 do you endure an entire album?
Absolutely not. Only certain music tracks. Some music is just meant to be played loud. Again, this is brief peaks, not sustained volume.
Correct, the peaks can reach quite high values, compared to the rest of the song, it all depends on the type of song and what you want to do with that song. Here we tested how much the system can take with the volume in the AV set to 0 dB....
Even at 24 cubits
It might be 24 cubits?
Even at 24 cubits on a summer night with windows open my system at full SPL is very audible, it even sounds good. I should take my SPL meter out there and measure. :cool:
Mean: 75dB to 90dB
Instantaneous PEAKS: 95dB
to 115 dB, just like an orchestra.
Music is dynamic. Particularly classical, some jazz, opera, film scores, etc.
OK. I didn't mean to be too pedantic, but i my initial proposal for this "usual listening SPL" I asked for the volume during a prolonged listening session because I was hoping this would represent ones listening habits more precisely. I also sometimes crank it way up to the red line just to see how my speakers perform, or how much they distort or, as you say, because some music draws you into crank it up. But that's the loudest, that's not how loud i Usually listen to.
Anyway, thank you for your input. I hope you cast your vote!
Mean: 75dB to 90dB
Yes, yes. This is indeed true. However that's why we set the rules of measuring for average. And if you play music for an hour, your average would be accurate enough for a pleasant, relaxed chit-chat such as this.
Thank you very much. Don't forget to vote.
Do you have a DR measurement for a classical album you'd call dynamic ? Just curious.
Or you can read the data directly from the music tracks...
11 on my guitar amp. But only if my wife is out. And not in a nearby street.
Look at the chart at this post, I have posted some in this thread.
Thanks, I'm just curious as the whether Classical listeners use a higher or lower on average level than rock, etc. We're all different but I don't believe we tend to vary that much based on genre preferences? I believe our poll here is a bit inaccurate due to users using a averaging mode rather than one accurately showing peak levels.
22 DR, give it enough juice and you can blow stuff
Ron Tutt, he's a rock and roll drummer. LOL
