NanoGuidingStar
- Joined
- Nov 21, 2024
- Messages
- 139
- Likes
- 156
Hello everyone,
Since last year I’ve been using Dirac Live ART. When adjusting the F Support Low (FSL) values, I’ve always referred to the specifications provided by the speaker manufacturer along with Dirac’s in-room measurements. As for THD, because most reviewers like amirm and Erin point out that bookshelf speakers tend to have relatively high THD in the bass region, I usually set an 80Hz crossover to the subwoofer to mitigate this issue.
Here’s the problem: Dirac Live ART doesn’t follow the traditional crossover concept. The lower the FSL setting for the supporting speakers, the greater the benefit to the overall system. In other words, within the usable bass range of the speaker, the FSL should be set as low as possible.
Take the Ascilab C6B bookshelf speakers as an example. F3 is around 52Hz. Based on my past experience, I would set their FSL to 60~65Hz. However, if we factor in THD (96dB@1M) from Erin, the speaker’s THD below 100Hz already exceeds 3%. This means that theoretically, setting the FSL below 100Hz could result in “distorted bass” being audible.
I’m not sure if this topic has been discussed before, but I really want to understand how to balance between a speaker’s bass performance and THD in order to determine a reasonable and appropriate FSL setting.
For most budget bookshelf speakers, their bass THD performance is generally poor (higher than 3%). Does this imply that they are all unsuitable for supporting bass below 100Hz? Or am I just scaring myself, overthinking?
By the way, my 7.2.2ch system is entirely composed of bookshelf speakers+subs. Normally, I set the AVR’s Master Volume to -25dB for movie. The distance from each speaker to my listening position is about 1.3–1.7 meters. Using a smartphone SPL meter to observe the playback volume while watching movies, I measured: minimum 45dB(A), average 85dB(A), and maximum 100dB(A).
