Not neededyour ears are seperated by a distance- agreed and that’s the reason why we hear everything binaural. And that’s the reason why we can have ITD and ILD, which helps us locate a sound object in space. Otherwise without that distance, every sound at every angle would reach both ears simultaneously
Yes.
And the arrival time difference at the two ears is how the ear/brain system calculates the horizontal angle, or azimuth, of the sound source. The ear largely stops paying attention to repetitions of the original signal (reflections) for directional purposes after a short interval which corresponds to the amount of time it takes for a sound wave to travel from one ear around the head to the other ear, like if the sound was arriving from the side. After this short interval (in which all repetitions of the original sound contribute directional cues) the Precedence Effect (or Haas Effect) kicks in, and further repetitions of the original sound are largely (but not entirely) ignored for directional purposes.
If the speakers have reflections or diffraction that arrive BEFORE the Precedence Effect kicks in (so, within .68 milliseconds of the first-arrival sound, or within 1 millisecond, or something like that, the exact figure given by researchers varies somewhat), the result can be FALSE azimuth cues. These false azimuth cues can blur the sound image solidity or specificity. Typically something like edge diffraction varies with frequency so the image solidity can also vary with frequency.
I speculate that the earlier-onset edge diffraction of a narrow-baffle loudspeaker results in smaller-angle false azimuth cues than is the case with a wider-baffle loudspeaker, and this may account for the observation that "small speakers usually image better". Or to put it another way, a wider baffle generally results in a larger angle for the false azimuth cues, which blurs the image location moreso than a smaller false azimuth angle would.
And just to be clear, this phenomenon all happens before, and independent of, the in-room reflections.
