Speedskater
What's with the 'RMS Power' is it the 1970's all over again?
Sure. Retro is a thing now, right?What's with the 'RMS Power' is it the 1970's all over again?
I agree with some of the comments on here. That music was picked especially for the demo.
1. Heavy bass content with no subwoofer meant that it all had to come from those amps.
2. The volume was turned up very high as the room was quite large, probably 30% or so larger than most listening rooms at home.
3. The second track of violins really showed what I am trying to point out. It had very little bass and they were hitting a peak of 28 watts at a very high volume on the preamp.
4. In reality, most people who want accurate bass in large amounts get a quality subwoofer. This will reduce a good portion of the bass and deep bass from the amplifiers. That alone would have dropped those 750 watt peaks by a good bit. It may have shown peaks of only 500 watts which is a big drop. But we will never know as that was not the point of the test.
5. I want to comment again as it can't be overstated. A large room and high volume was used. As I believe he stated it was much higher than anyone would listen to normally. Those violins were screeching like crazy and now your in hearing damage territory. But I can't really tell for sure as an important technical point was left out. What was the listening SPL range? It doesn't have to be specific, just a range. If your in the 60 to 70 range you know that, if in the 100 to 105 range that is something you can also tell with a cheap meter. But to have no idea at all was a let down of the "test". I am making an assumption as 500 watts RMS, 750 watt peaks into most speakers will be the max (or over max) they can play at over the long term, they are beating the drivers pretty hard. I have tested drivers to failure many, many times. That was almost a torture test and as torture tests go a very short one that didn't cause any problems. After a few hours they may (we will never know) have let the smoke out of the speaker box!
To get me to respond like this shows that this is a fantastic thread! Very enjoyable.
OMG! --- have you been running into GeorgeHiFi over at Audiogon?
Everything is about "the doubling down", and all comments should be interpreted with respect to their relevance to "the doubling down".
That's the one. I was thinking it was millercarbon of the thousand amps.
No that would be not so curious George. While his is very anti-fuser and most things, the has some weird ideas about amplifiers and how they work. Basically he does not know how they do, and fill in the gaps with guesses based on limited knowledge. Millercarbon is just generally wrong about almost everything, but that has never stopped him or his tall tales.
I’ve noticed Millercarbon is all-in for Ted Denney, which is consistent.
So if my speaker is a complex load (not efficient , low impedance, high phase angle, etc) and I want to be able to get the full dynamic of any music out of my speaker, what is the spec I should look for in choosing Amplifier?
Double down = more headroom ?
Do you have opinion what amplifier spec/measurement that may explain why the certain amplifier have more dynamic than others? Is the doubling down a measure of its dynamic capability?
Thanks
No, strictly it is not. The "doubling" of power into 1/2 the impedance is in reality a marketing moving-target. In some instances a manufacturer may believe it is in their best marketing interests to choose an 8 Ohm rating which is a bit more conservative so that they can market the 'ability' of twice the power into 4 Ohms. We make an amplifier which can in reality do this without hocus-pocus, but it takes a lot of design work and a lot of money. Obviously closer to the ideal is better than a large discrepancy between the impedances, but be aware that there is a lot of marketing involved not just in amplifier power but in audio in general. There are hard electronic facts which are not bendable, but marketing tries to bend them at every opportunity.I plan to replace the old Krell KSA200s with something newer (so was testing Class D Amp).
Therefore, I am asking the question whether the double down attribute is important (in playing dynamic music) for my next amplifier purchase/upgrade. Sounds like the consensus is "it is".
A salesman at a professional audio company I used to work for told me outright that 'salesmanship is controlled lying'.No, say it isn't so!! Audio gear sold on incorrect measurements? Also, known as lying. Marketing bending scientific principles? Would that be snake oil? Here I thought audio was an honest business.....well compared to a heroin dealer. Audio sales=crack/heroin dealer. If everyone bought audio gear with that in mind, much of the audiophoolery would go away. Remember if your talking to a salesman there is an 80 to 90% chance they are lying. Thoughts to live by!
The thermal dissipation aspect is becoming a very big deal in designing new amplifiers, especially multi-channel ones. Actually, because of various requirements and regulations, its becoming an incredibly big deal.Dynamic range is a function of noise floor (SNR) and power output. Different manufacturers may specify amplifiers differently, even within their own product line. A conservatively specified amplifier may actually provide more power than one rated for higher power especially if it is specified for low-impedance loads and "doubling down". Thermal (heat) requirements, power supply capacity, output device safe operating area, and a myriad of other factors come into play. The opposite is also true; an amplifier not rated to "double down" all the way to 2 ohms may provide more power but simply not have the heat sink and power supply to sustain long-term high-current output for low loads. So it might not be rated to "double down" but in real life may sound far more powerful.
Like many things, there is not a simple single specification that tells everything about the amp.
