How hot should your AVR be at Idle?
Tanquen
California Bay Area
It's winter now, like 63° in the house and I don't ever remember the extra fan coming on before, without the unit being on.
I checked the temperature and it said it was 80° even though it's been off overnight, for at least 10 hours. I've never checked the temperature before.
Does that seem high?
what do you mean idle? is it completely off or on without playing anything?
If I turn on mine (Denon), it will draw 70w for doing nothing, and eventually it'll be warm. I can see yours is quite similar (x4800h probably ?).
I would try one night with it unplugged and remeasure temp so you have a differential between completely off temperature and standby temperature.
That seems high, but I wonder if it's normal if you have Eco Mode switched off? I left that particular feature on, and my Marantz NR-series AVR doesn't seem warmer than ambient temperature.
It should not be warm when in standby. I had a similar problem with my x2600h. Solution found online.
After a complete factory reset the problem disappeared.
You will lose all settings though. Calibration etc has to be redone...
General good rule is to not stack to units on top of each other if you can avoid it. Also, raise like 1cm or so so more air can come inside from the underside
Idle, like it's not doing anything for me but it's still plugged in. Soft powered off whatever you want to call it, standby.
It's the X6500H.
Eco mode is off. But it just seems kind of warm for being off or in standby but still plugged in.
I've just done a couple of factory resets not too long ago. But I had backed up and then restored the settings. Unless the issue is hidden inside one of the user configurable settings. I'm not sure what that would be though.
The shelving's pretty open and the only thing directly on top of it is the extra fan.
The temperatures just seemed kind of high for it being off/standby overnight and of being relatively cold in the house.
It's the X6500H.
Too bad reset did not work. In my case it was so warm I could smell the unit in standby. (2nd hand purchase, probably dusty ...).
I think that after switching off it activated zone 2.
Some type of bug, not a setting I think.
I remember something on standby for remote app, network.. it's not really off. That means power supply does something. I heard some AVR have a second one for these low power operations?
It's the X6500H.
Then check the power consumption. It should be 70 -80w and that will turn to heat. If you worry about heat, improve ventilation
At standby it should take 0.5-2W, depending on settings. The box should remain practically at ambient temperature.
Ironically the AVR is fully covered by the fan box. So the idle heat will tend to build up until the fan comes on.
Measuring the consumption should be telling. I switch power off for the whole HT when not in use. Initially because of consumption.
